Question about Fujitsu (MHV2120AH) 120 GB Hard Drive
Hard Drive is not reading
I removed my original Fujitsu hard drive from the laptop and when I am installing it again it gives a message "Operating system not found" on my laptop screen. When I checked my connections again I found pins on laptop and hard drive are not touching each other. How can I fix up this problem? Is there any pin connector available to fix up this problem?
    Problem Solver:
  • 14 Answers
Whoops!
Are the pins BENT out of alignment? It is SO easy to create this problem when connecting a drive.
If the pins are bent use the greatest of care putting them back in alignment with the other pins. Now carefully reconnect the drive.
Hope this helps!
Posted on Feb 24, 2009
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
Tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
on Oct 02, 2010 | Computers & Internet
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Oct 30, 2012 | Toshiba Computers & Internet
No bootable device insert bootdisk and press any key
Hi! Welcome to www.fixya.com.
Firstly, You need to check the boot sequence in the BIOS . Start your laptop then keep on tapping f1 or f2 then check the boot option. Make sure the Boot priority is the HDD. Secondly, Try to get reboot the computer to factory settings; 1 Ensure all Data is backed up, all data will be deleted.2 Please also ensure that all USB storage devices are removed before starting the recovery process
3 Restart machine
4 When your unit switches back on, wait for the ACER screen then hold down alt & tap f10 repeatedly..
5 Please wait a moment until prompted, -How would you like to restore?-
6 Please select -Restore system to factory default-
7 Enter your defined password or enter six zeros '000000'
8 Click ok
9 Please wait until process completed, this will take 45min - 1hour
ALL personal information on the C: Drive I.E photos, programs, music and documents will be wiped when the above steps are taken. Files located on the D: Drive will be safe from the procedure.
Read more: I need to reset my acer laptop to its original factory settings but I do not know how...can someone please give me some instructions? ' Answerbag http://www.answerbag.com/q_view/666664#ixzz1SLoK8jYp
You can purchase the OS from Acer then reinstall the Operating system.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 17, 2011 | Acer Aspire One PC Notebook
Laptop not working Packard bell message on screen says BOOTMGR is missing
HI
I Think the laptop is trying to read the hard drive to boot up and its got a problem reading it
it may be worth turning off the laptop unplug the power core remove the hard drive from the base of the laptop usually only one or two screws to take off the cover and normally quite easy to remove
then try to start up the laptop
then turn off again
give the hard drive a quick blow over the connections
replace the hard drive
and try to boot up again
if this dont help
press power up key as well as the F8 key
this will hopefully take you into the repair options
and try the last good known configuration
or
repair my computer
if this does not work then the hard drive may be corrupt of dead
which is not good new if you havent done any backup disks or have any recovery disks
or a operating system install disk
hope you get it sorted
Jul 07, 2011 | Computers & Internet
I have a FS Lifebook E4010 typ laptop. Recently the HD was changed to a larger one, and XP Pro OS was installed on it. Now the booting process starts, and after 5...10 seconds breaks, and starts again,...
The replacement hard drive sounds defective, remove hardware and re-seat it back into place, If there is still no change remove the hard drive take it to where it was purchased and have them test the hardware for issues.
Jan 25, 2011 | Fujitsu Siemens LifeBook E4010 Notebook
When i format my laptop it gives an error message that the hardrive is not installed
Most likely your hard drive has died, taking all your data with it. Nothing you can do to fix that apart buying a new hard drive and reinstalling Windows on it.
Jun 08, 2010 | HP Compaq 6710b Notebook
Hi when I turn on my fujitsu amilo pro v2055 it says operating software not found. Can anybody help
The operating system software is stored on the hard disk. The computer cannot detect the hard drive and therefore cannot load the operating system. It could be that it only needs reseating to get it operating again, if that does not work it could be a faulty disk drive or a faulty disk controller.
To test if the hard drive is OK, remove it and connect it to an USB hard drive adapter and plug this adapter and drive into a working computer's USB port. If this computer see this as an external hard drive and you can view the contents of this drive, then it is OK. If you cannot see this drive then it is faulty.
You need to replace the hard drive in your computer and install Windows again to get an operating computer again.
May 16, 2009 | Fujitsu AMILO PC Laptops
Operating system not found.
The hard drive has either been damaged and can't be read, or its connection was knocked loose from the motherboard. Open whatever cover necessary on your computer to get at the hard drive and make sure any connecting cables are properly seated. If the drive was damaged by the fall you will need to replace it and restore your system.
Apr 05, 2009 | Fujitsu (MHV2120AH) 120 GB Hard Drive
Fujitsu (MHV2120AH) 120 GB Hard Drive Logo
194 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
