Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not high spin
Whirlpool Ultimate Care 2 washer will not high spin and sometimes will not spin at all
    Problem Solver:
  • 13 Answers
It sounds like a set of clutches would fix it. If not clutches...transmission. :(
Posted on Feb 27, 2009
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Posted on May 21, 2008
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II spins only once in a while :-)
hi there,
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 washer wont spin
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not high spin
The brake assembly is failing ,try this if you can,loosen the 3 transmission bolts about a quarter inch and try it in spin.If it picks up speed than you are going to be due to have the break assembly replaced.High cost repair. :(
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II LSQ9264HQ SPIN won't spin
WILL NOT SPIN BUT MAKING A CLICKING NOISE
SOMETIMES I CAN GET IT SPIN IN LITE SPIN MODE
Apr 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer
it sound like the drive block under the agitator is worn out does the bowl lift up and down?.remove agitator to see the drive block.
Jan 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
438 people viewed this question
Dan Webster
Dan Webster
Sal De
