Question about Maytag Atlantis MDE7400AY Electric Dryer
Need help converting 3 prong to 4 prong on MDE6200AYW DRYER. I have a three connector terminal with yellow and black on the right, white in the middle and a pair of blues on the left.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding in your region, the 4 wire is the new electrical code. The only difference with the old styled 3 prong is that the neutral and ground are now separated thus making it into a 4 wire/4prong.
You might be better off looking over the illustrated instructions here or here.
Additional pointers to guide you:
  • almost all electrical type dryers uses 120 for the controls and 220 only for the heater;
  • in most instances, the yellow has a green stripe;
  • to confirm which is which, an AC voltmeter would be required on the outlet and a continuity tester on the dryer (unplugged). A DVM/VOM would serve both purposes.
Good luck and thank you for using FixYa
Posted on Feb 24, 2009
    Genius:
  • 1,269 Answers
You can see the diagram on the manual that came with it.
    Brigadier General:
  • 8,619 Answers
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    Hi
    You need the black, red, and white wires connected to the terminal and the green connected to the frame . As shown in this Picture.
    Please revert for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    The fourth wire is to ground the body of the dryer. The cord should have red, black, white, and green wires. Red and black are hot, the white is neutral, and green is ground. The red, white, black in that order or reversed, black white, red, should go in a row where they connect to the dryer with the green one probably above it. If the center neutral lug has a bond to the chassis remove it. You have a dedicated wire to replace it now.
    Please revert for any clarifications.
    Thanks
    Rylee
How do I change a 4 prong to a 3 prong dryer code
When replacing a 4 prong cord with a 3 prong cord you put black and red wires to the outside posts of your terminal block. The white wire from your three prong dryer cord goes to the center of your terminal block. The yellow and green wire from the dryer go together and attach to the cabinet ground.
Nov 22, 2014 | Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Aug 13, 2011 | Kenmore 700 6972 Dryer
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
I have a new GE DCVH680EJ1MS Electric Dryer that I want to run 240V. I see it has Black/Red/White and Ground and this tells me that I "MUST" have the same in both cable to attach as well as female...
This is a prong conversion problem and all you have to do is convert from 4-prong to 3-prong. Your suggested configuration will not work, damage the dryer, and pose a fire hazard. The correct way to convert from 4 to 3-prong is by using three of the four wires; black, red, and white (neutral), and then connect the dryer frame to the neutral terminal. It is similar to making the neutral (white) and the ground terminals as one.
Mar 25, 2010 | Dryers
I have a 3 terminal electrical connector dryer and need to replace with a 4 terminal connector. I went to home depot and got a 4 terminal connector that has a balck,green,red,and white connector but when I...
The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green.
For safety's sake, put the Red on the right post, white in the middle, and black on the left. The green gets grounded right to the case.
Jan 02, 2010 | Dryers
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
