Question about Samsung 7.3 Cu. Ft. Super Capacity Electric Dryer
Samsung Washer DV316/LES/xaa model will leave clothes wet
I have to add an extra spin cycle just about every time because the clothes does not rinse properly. Technician came out tried replacing the board problem still occured. The loads are not that heavy either. Any suggestions.
    Top Expert:
  • Samsung Master
  • 12,962 Answers
Belt is slipping and not spinning drum to correct speed Replace here. Search Over 2 1 Million Appliance Parts
Posted on Sep 12, 2017
SOURCE: Fabric softener not draining during rinse cycle
What type of water hoses are hooked up to it? If you have the flood safe hoses with the check valve in them then there isn't enough water pressure to distribute the softener.
Posted on Jun 11, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Posted on Feb 12, 2009
  • 38 Answers
SOURCE: New front load washer dryer is vibrating badly when drying
Q - My washer keeps moving around n the floor, is there any simple things that I can check ?
A - Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Mar 14, 2009
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
SOURCE: my samsung wf448aap washer leaves clothes smelling
How much detergent are you using? Try using less detergent and softener in your loads. Too much detergent can leave clothes smelling similar to a wet dog, like you described.
Posted on Sep 05, 2009
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
I have an issue that is rather strange! On the NORMAL cycle only, at the end when it should turn off, a rinse comes on and wets the clothes. The extra rinse is NOT on, the belt and motor are fine. I know...
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details.
BUT, is this an "LAT" series Maytag washer??
If so, this is a normal rinse, the manufacturer calls it a "Spray Rinse" and it is quite normal.it only adds the water during the spin cycle, after the rinse water is ejected and then only for about 1 minute, the water passing through the fabric as it passes by the water inlet flume and empties during the spin.
Jun 12, 2017 | Maytag MVWC6ESWW Washer
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
Indesit moon not spinning as it should
my machine is similar...............but has an extra rinse button which adds 5 minits to the wash.....but spins faster to get rid of extra water...............see if you have extra rinse option......
cheers
Jul 24, 2017 | Indesit W 123 Front Load Washer
Washer leaves clothes extra wet, need to dry double time
when it spins can you stop it with your hand, to try this put it in the spin cycle then push the lid switch with a pen and hold the tub if you can your problem is a spin basket drive if you cant then let me know
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Samsung 7.3 Cu. Ft. Super Capacity Electric Dryer Logo
228 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
