Question about JVC KD-G210 CD Player
No sound on coming out of speakers and theres no wires touching everything looks like it works fine
    Novelist:
  • 152 Answers
Make sure you didn't accidentally hit the mute button.
You should always test sound with a CD, testing sound via AM/FM will produce interference and almost no sound when between stations, also don't to forget to connect the antenna lead.
Check that the speakers are wired correctly.
Check that the sound controls are adjusted properly, i.e. Balance, Fade etc.
Good luck...
Posted on Feb 24, 2009
Static coming through the speakers even though the radio is unplugged and the fuse is takin out what worng?
After I read this whole post and the solution by other guy. I came to my own conclusion is that you may have an exposed wiring that causes the static sound out of speakers. Try to look for bare wiring that may have touch each other as well as touching the metal of the vehicle. Try to disconnect the wires at the speaker, and see if it works. If it does works, then you know that you have wiring issue there.
Mar 06, 2014 | 1996 Lincoln Mark VIII
Stopped working
Speakers wire conductors should not touch anything but the points on the amp and one speaker terminal each. Look again.
May 20, 2010 | Pioneer VSX-918V Receiver
My 2005 Accord's radio / CD player will not produce sound to the speakers, the display panel works fine. Sometimes a loud static sound will come from the speakers with no volume control, powering off gets...
The sound chip may have gone in the stereo, especially if someone has had it on very loud they sometimes blow, otherwise you have 2 speaker wires touching each other, that way you only get static noise, insidee the door they sometimes come free and touch the body
Check all your speaker wires first.
Jan 17, 2010 | 2005 Honda Accord
Sony STR K840P, protect mode is flashing,no sound,nothing come out. When starting every thing is fine for 20 or 30 seconds and the "protect"start to flash and nothing geht anymore,everything is blocked
This is a classic problem. One of your speakers is miss wired and or your speaker wires positive and negitive leads are touching. Check all connections from the back of the reciever to the back of the speakers to make sure your positive and negatives are correct and that none of the wiring is crossed or touching one another.
Jul 24, 2009 | Audio Players & Recorders
My RCA RS2622 sound stopped working.
I'll need to look up your specific model to be sure, but I believe that the speaker outputs come from an amp pac. The headphones are driven by an opamp IC. The outputs are blown on this. If you can solder, you should be able to repair this. I'll look up the parts required and get back to you.
Dan
Aug 29, 2008 | RCA Audio Players & Recorders
System was working fine and now there's no sound, but deck still does everything else.
The speaker wiring might be damaged. ( cauese :- Wires getting caught to door, Heavy weights can also seperate wires by breaking them ).
PLEASE RATE ME AS ( FIXYA ) <BLUE BOXES>...............
May 27, 2008 | Alpine CDA-9830 CD Player
Speaker trouble
MAKE SURE NO SPEAKER WIRES ARE TOUCHIN THE OTHER, IF DONT WORK.. YOU WILL NEED TO TOUCH TWO WIRE AT A TIME, DID YOU HEAR SOUND BE4 INSTALLING
Mar 25, 2008 | Car Audio & Video
No sound coming out of speaker, but headphone jack works!
Hi, I had the same exact problem. The speakers wouldn't work but sound came out of the headphone jack.
To fix my problem, i opened up the subwoofer unit and checked the fuse on the circuit board which seemed fine. Then i had a look at the wiring on the other side of the circuit board and noticed one of the wiring had fried leaving a gap in the connection and exposing the copper wiring. So i just soldered the two bits of wire together. Works fine now!  I just had to be careful when i finished soldering that the exposed wire wouldn't touch any of the other connections. I insulated the wires with a glue gun to keep it all in place.
hope this helps.
Jan 22, 2007 | Logitech X-530 Computer Speakers
JVC KD-G210 CD Player Logo
336 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
