Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Electrical spec for frigidaire gallery washing machine
I live in an off-grid solar powered house. I do not have 220vac. Does the frigidaire galley frontlaoding washer operate on 110vac or 220vac. I can't find a spec sheet or any info about this anywhere on the web.
thanks,
  • Paul Potyen Feb 24, 2009
    Thank you Clarkco! Do you have a number for the wattage of this puppy?
  • 360 Answers
110v 60hz in USA
clarkco
Posted on Feb 24, 2009
Is this true or scam Government pays you to go solar.
The US government WILL NOT PAY you to go solar. There have been incentives on the state level to get people to install solar panels. Most of these have dried up but it is possible to find programs that will reimburse you a portion of the total cost but don't expect much. We live in Florida and in 2009 we were promised nearly 1/2 back if we installed. We got less than 10% when all was said and done and it took 2 years to get that.
Aug 18, 2015 | Miscellaneous
Is there a new method to slash your electric bill?
75% is a pretty lofty claim! There are solar grid tie systems that you can buy now that are pretty DIY. I have my eye on a 1000w system right now and that will cost around $3000 for a simple to setup system. Grid tie means you are making power and putting it on to the grid or using it in your home. When power is lost, however, the grid tie is not going to provide power in an outage. It will provide additional power from solar during the day which reduces the amount that your meter moves or in some instances (depending on wattage of system) you can even run your power meter in reverse and earn credit. Another method is to just turn things off that aren't being used. You can also replace old incandescent lighting with CFL or LED lighting which use considerably less energy.
Mar 02, 2015 | Audio Players & Recorders
How many cubic ft. in a 2001 Frigidaire Galley model #FWT647GHS washing machine
Hello friend, that's a great question!
I understand you would like to know the cubic footage of your Frigidaire washer. Based off the model number you have provided your washer appears to be a 4.4 cubic feet washer. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Washing Machines
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
Jan 15, 2015 | Inverter Electronics - Others
Frigidaire gallery washer
Not likely that the problem is a pump.. Water usually comes into the machine under the normal pressure of your water supply. Hence, pump problems usually manifest themselves by not pumping the water OUT of a machine. First, check that the electrical power is coming to the machine. If it is.... and your water is definitely turned on..... you most likely have a problem with a switch, or relay or something else inside the machine.. Probably time for a repairman...
Jan 03, 2014 | Washing Machines
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
Dec 11, 2013 | Washing Machines
How do you change lint filter
Hello ccparish8 - Base on the model listed above on the post, washer GLWS1339EC does not have a lint filter or any of Frigidaire washing machines. However, if you are referring to replacing the lint filter on a dryer, simply remove the lint filter from the housing and reinstall in the same manner.
Feb 24, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
No water enters Frigidaire GLTF2940FS1 Washing Machine when run
You will want to contact Frigidaire and ask them the sequence.
Dec 22, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
287 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
