Question about RIM BlackBerry? Curve 8330 Cellular Phone
Internet setup - RIM BlackBerry? Curve 8330 Cellular Phone
    Problem Solver:
  • 5 Answers
1. go to the wrench (options)
2. select mobile network
3. service provider should show in the mobile network ( sprint, at&t , t-mobile )
4. click on the provider a menu should come up scroll to start provisioning
(note: make sure you are in your service network before provisioning, i am always roaming and have to drive half way to the town next to me just to get my phone to work
Posted on Aug 18, 2010
How to setup tp-link TL-MR3220 on xp2002?
Connect the router's WAN port to your cable-modem.
Connect the computer to one of the LAN ports.
No other "setup" is needed.
Apr 29, 2014 | D-Link AirPlus DI-524 Wireless Router
The internet button is on, but I don't get internet from the router, only directly from the modem.
This an wire setup gone wrong!
The wire you use to get the internet from on your modem, plugs into I believe a Yellow port at the back of your router.
The rest of the ports are for hardwiring each computer.
So your computer, We say #1, will have a wire from you LAN card at the back of you computer to port #1 on you router.
you will have to go into your windows internet setup to change some settings. So to do this
My computer, Control Panel, Internet setup.Internet wizard setup.
You no longer SAY you use modem for internet, but setup through router.
This will NOT be a new setup but an existing setup
Aug 05, 2010 | Linksys Computers & Internet
I am trying to setup a internet connection using yahoo what do i do
Sir,only using yahoo connection it will not provide to setup internet connection.
For internet connection you have to configure all the component which provides you to connect with internet.
These configuration requires LAN card,LAN driver,modem,NIC card,phone and internet service provider to assist the internet to activate the internet.
Apr 12, 2010 | Computers & Internet
How to setup Linksys Wireless-G Broadband Router WRT54G. I want to stetup my computer, wireless, to another computer with internet access
Have you already setup one of your computers to connect to the Internet using the wireless router?
If so you can setup the second computer the same way and it also will connect to the internet. There is no need to access the Internet through the other computer.
Sep 20, 2009 | Linksys Computers & Internet
We are connected to the internet by a satelitte dish. The modem works fine when connected to the desktop computer but when I try to run it through the router I can not connect to the internet. Is there a...
hello! i will be more than glad to assist u in this concern..the possible solution here is u need to setup the internet connection setup on the router.. there are many option like, dynamic setup-this is auto detect, static ip or pppoe, check the type of setup from ur isp.. ex. ur setup is static ip addressing, to check the settings, connect ur computer directly to the modem and from the computer click on start, run and type in cmd,dos prompt will appear, type in at the prompt, ipconfig/all and write down from a piece of paper..the ip address, subnetmask, default gateway , dns server, then u need to type in the info at the setup page of the router on the internet connection setup and selct static ip, if u are using a pppoe, u need to setup the username and password given to u by the isp and set it up to the router and make sure that ur going to disable the pppoe software u used from ur computer.. if u are using a cable modem u need to mac clone the nic of ur computer.. i hope this will help u.. good luck
Aug 03, 2009 | D-Link DIR-615 Wireless Router
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
RIM BlackBerry? Curve 8330 Cellular Phone Logo
120 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
