Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a Kenmore Refrigerator that a friend just gave me that is about 5 years old in good condition. On the move we didn't lay it on it's back, but of course it was tilted back at times. Transported it standing up in the truck. It won't start cooling at all. It is blowing but not cool air or freezing? Any suggestions?
  • 4 Answers
How long have you let the unit run? Sometimes if you leaned it back too far you need time for the oil in the compressor to recess..to go back into the compressor. It normally takes a refrigerator 24 hrs. to cool but also up to 72 hrs. if after three days of continous run and not cool at all then you have a restriction in the system, in this case oil in the lines or a stopped up liquid line dryer. It's a filter for moisture and impurities in the closed system. Otherwise give it time to cool without putting the settings all the wayup. Put them on the factory settings usually in the middle of both knobs or whatever you have for adjusting the coolness. Overheating the compressor will not cool the unit and you might try shutting the unit down for a day and then resume again the next day at middle or lower settings. Make sure never to lay a refrigerator over on it's side! The life of a refrigerator should be up!
Randy
A.I.R. Appliances
San Antonio, Tx. 78209
210-822-1818/210-493-2700,cell 210-264-1471
Posted on Feb 26, 2009
How long is sewing thread good for
As long as sewing thread is kept in a dry place - often a biscuit tin or one that has held confectionary is used - then it should remain in good condition for a very long time. I have cotton which is probably 30 years old, and some inherited reels which could be up to 50 years old and which are still in perfect condition.
May 02, 2014 | Kenmore 11206 / 11306 / 11506 / 11606
Moved 9 year old kenmore to friends house just replaced ice maker. lights come on but refrigerator is not getting cold water is running ok but is warm
Is the freezer getting cold?
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Moved the fridge to lay new flooring now that it's plugged back in the interior light didn't come back on. Help.
Used Multi - Tester if Convenient Outlet is alive..
(if not so sure) dont try to test it..
Aug 19, 2011 | Samsung RB2155SH Bottom Freezer...
I just sold my Magic chef refrigerator (20.8 cu ft). It was 2 years old . I plugged it in for the buyer. It got cold as it worked perfectly. the buyer said he was going to lay it down to transport it...
i have been i the appliance service industry for approx. 18 years and everytime i see someone lay a refrigerator down or talk about it i literally cringe.... it can be done and sometimes will work ,but what happens if it does not sit upright and notice i said and all the oil runs back down it will fail everytime.... the oil gets in the evaporator and then will not run correct when the compressor comes on it pushes that oil through system and will clog capillary tubes and or slug unit creating it not to pump properly.... guarantee this is what happened to the unit... if it indeed worked fine before you sold it he either allowed oil to saturate the evap coil or something in the sealed system broke in transport causing freon to leak out...
Jan 26, 2011 | Magic Chef CTB2125 Top Freezer...
Does it hurt a five year old refrigerator to lay it down while in transit?
If you lay it down for any reason , let it stand for 24 hours , before plugging it back in . This will give the oil , time to get back into the compressor . If you do not wait , and plug it back in , the compressor will try pumping the oil , without the refrigerant mixed , thru the system . This will cause restrictions , in several different places , which cannot be repaired . Restrictions will start in the dryer , then the accumulator . Basically the refrigerator will be useless afterwards . Warranty will not cover this .
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore top freezer. Bought it from a lady. Only
Was the fridge layed down when moving ? If so , did you let it stand for 24 hrs before plugging it in ? If you layed it down and didn't wait to plug it in , it's no good .
If you did not lay it down , remove the back panel and see if the compressor is running . If the compressor is hot but not running ,possible overload/relay bad . This is the piece that plugs onto the compressor . Also check that the fan that cools the compressor is working .If you remove the inside freezer panel , check to see that the freezer fan is working . Check to see if the coils are getting a light coat of frost on them .
Aug 21, 2009 | Refrigerators
Refrigerator not cooling
Dear friend,
ngfam at you service! happy to assist!
Whats the size , model number, and year of the fridge?
And i'll try to figure it out!
Dose it have a black grille of tubes running up and down the back that you may have bent in transport??
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Kenmore Refrigerators
Funny smell from RS2630SH
Dear friend,
Whirlpool sells odor stoppers for your fridge!
And keep a open box of baking soda on the door always!
HERE IS THE WHIRLPOOL SITE BELOW
http://www.whirlpool.com/catalog/
accessory_category.jsp?parentCategoryId=
323&categoryId=370
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
Aug 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 20 porcelain plus refrigerator
5' 6" Tall
32 1/2" Wide
28" Deep
I bought that old fridge at a garage sale for cheap. It's been enjoyed for me for just over a year. :)
Jul 17, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
