Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Install printer cartridge issue
I know this is a silly question but I am electronically disabled. When installing toner cartridge for MS3200 printerdo you remove tab A and the attached tape and discard or do you let it dangle?
    Genius:
  • 2,120 Answers
Pull it completly off and discard.
Posted on Feb 24, 2009
Every page I print out has a vertical stripe down the left hand side of the page.
(1) Clean the corona wire in the drum unit.
(2) Check that the wire cleaner is at the home position.
(3) Check that the toner cartridge is not empty.
(4) The drum unit may be damaged. Install a new drum unit.
(5) The toner cartridge may be damaged. Install a new toner cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 25, 2011 | Brother HL-2040 Laser Printer
I have a printer dcp 7030 brother company i am showing problem 'toner life end change your cartridge' after reffling. i have no new cartridge what can i do?
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
this will reset toner counter on a lot of brother printers good luck
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Brother DCP-7030 Digital All-in-One Laser...
HP PSC 1310 all in one Printer refuses refilled cartridges after 100 pages
Try swapping in an old cartridge TEMPORARILY... HP tried to prevent refilling by reading an electronic serial number from the cartridge and would not accept the same cartridge re-installed... using an old one temporarily fools the silly firmware...
Dec 10, 2010 | HP PSC 1315 All-In-One InkJet Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
Installed new toner cartridge on hp laserjet 2300 and getting install cartridge error on LCD
Its possible that you just got a bad toner cartridge. There is a chip on the toner cartridge that could be bad. I would shut the printer off and then back on. Confirm that the tape has been removed then firmly reset the toner cartridge back into the printer. If that doesn't work then try another or the previous cartridge. This could be an issue with the printer but I find that very unlikely.
Aug 31, 2010 | HP LaserJet 2300N Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
Printer saying ink cartridges not compatible when they're the same cartridges that have been in there for ages. Printer lights flashing and says E5 on screen.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | Canon PIXMA MP160 All-In-One Printer
KONICA MINOLTA 2430 DL - BLACK NOT INSTALLED, CYAN NOT INSTALLED
Unfortuanately, the only solution that I know of is to purchase new chips ($15 ea.) There are multiple websites that sell these. I had the same problem and have resolved it in this mannor. I tells the printer that it is a new toner cartridge. There is another post in 'fixya' that explains howt to disable the 'reading' capabilities of those chips. You have to go into your status display box, printer, mode setting, then uncheck auto toner replace and restart printer. It is supoose to do away with the 'reading'. I tried it BEFORE replacing my toner and it didn't work. You have to replace it first, then follow those steps.
Jun 15, 2009 | Konica Minolta magicolor 2400 Laser...
Toner light is still on
If you put new toner in your used cartridge and you still have the Toner light, you need to reset the "reset gears". Take the cover off of the gear side of the cartridge. The reset gears are actually attached to the inside of the cover. Move the gear with the lever to the opposite side of the current position.
Nov 30, 2008 | Brother HL-2170W Laser Printer
Install Toner Msg
I had the same problem when I had the cartridges refilled. Aparently some electronic part inside the cartridge needs replacing when a cartridge has been re-filled. If its a new cartridge i do not know the answer.
Cheers,
David J.
Jul 10, 2008 | Samsung CLP-510 Laser Printer
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
old marine
old marine
