Question about Apple iBook G4 Mac Notebook
Mac OS X
Hi. I can't find this anywhere.
On My Mac Login Screen (where you choose user) there is a message
Ex: (jl's computer)
I need help figuring out how to change this.
Help is greatly apreciated
(I'm more of a Windows Guy)
  • 32 Answers
The only way to change this is reinstalling the system with start up disks,
actionman
Posted on Feb 27, 2009
Testimonial: "Thanks."
I forgot the administrator password, there is a malware protection software I believe. Is there any way to recover password?
You need to restart with original media disk and then you can choose reset password from the apple menu bar.
Mar 14, 2015 | Apple 24" iMac Desktop
Forgot user password
Hi I'm Peter , You can change your user password by going in with your administrator password. Here are a few helps https://iforgot.apple.com/password/verify/appleid and see
http://support.apple.com/kb/HT1274 and
and Kappys answer
https://discussions.apple.com/thread/4251616?start=0&tstart=0
In OS X Lion or later, you can reset your user password with your Apple ID.
In Mac OS X v10.6.8 or earlier, follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
    http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1274/HT1274_Leopard.png
  6. Hope this helps.
Apr 20, 2014 | Apple eMac G4 Desktop
Kocaso nb726a
Resetting a password without an additional account Use these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
After following these steps, you need to update your keychain so that it recognizes the new password.
If your computer doesn't have an optical drive, connect it to a computer that does using Target Disk Mode, or use the Remote Install Mac OS X utility to start up the computer remotely. Resetting a user's password in Mac OS X v10.5 or earlier If you are using an earlier version of OS X, select your version number below for password reset instructions. Avoid setting a blank password for a user account when using these steps. Mac OS X v10.3 through 10.5.8
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" above.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the name of the user whose password you want to change.
  6. Click the Reset Password button or the Change Password button.
  7. Enter a new password in both the New Password and Verify fields, and add a Password Hint if desired.
  8. Click the Reset Password button or the Change Password button.
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Mac OS X v10.2 through v10.2.8 Use Accounts preferences to reset an account password.
  4. Click the lock button if it appears locked.
  5. Select the username whose password you want to change.
  6. Click Edit User.
  7. Navigate to the New Password field.
  8. Enter a new password in both the Password and Verify fields.
  9. Click OK.
  10. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Regardless of how many characters are actually in a Mac OS X v10.2 password, seven bullet characters (•••••••) will appear in the New Password and Verify fields the next time the password is edited. Mac OS X v10.1.5 or earlier Use the Users preference pane to reset a the password.
  3. From the View menu choose Users.
  5. Select the username whose password you wish to change.
  6. Click Edit User.
  7. Enter a new password in both the Password and Verify fields.
  8. Click Save.
Important: Passwords for administrator accounts should not be blank.
Regardless of how many characters are actually in the password, thirteen bullet characters (•••••••••••••) will appear in the Password and Verify fields the next time the password is edited.
Jan 01, 2014 | Computers & Internet
I have apple i book g4 i forgot my password.
Changing your administrator password
To change the administrator password, you must know the current administrator password. If you're logged in as the administrator, open Account preferences and click the Change Password button.
If you don't remember the password and automatic login is turned off, you can reset the administrator password using the Mac OS X User Install disc.
IMPORTANT: Because a user with the Mac OS X install disc can gain unrestricted access to your computer, you should keep the disc in a safe place.
To reset the administrator password using the Mac OS X disc:
  1. Insert the Mac OS X Install disc and restart the computer.
  2. When you hear the startup tone, hold down the C key until you see the spinning gear.
  3. When the Installer appears, choose Utilities > Reset Password.
  4. Follow the onscreen instructions to change the password.
  5. Quit the Installer and restart your computer while holding down the mouse button to eject the disc.
Be sure to change your login password in Keychain Access to match your new password.
Aug 05, 2011 | Apple iBook G4 Mac Notebook
How to reset the admin password for my Mac OS X 10.2.8
If you have your Install CD
Start up from a Mac OS X Install CD.
Hold the C key as the computer starts to boot from the CD.
When the installer starts, choose your language, and you'll proceed to the welcome dialog.
Important: Do not select "System Administrator (root)". This is actually a reference to the root user. Do not confuse it with a normal administrator account.
Enter your new password. Click Save.
Quit the Reset Password tool, and Restart your Mac.
Once you restart your Mac, you should be able to log in with the newly changed password.
If you don't...
This should work for your version:
To reset your OS X password without an OS X CD you need to enter terminal and create a new admin account:
Reboot
Hold apple + s down after you hear the chime.
When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
After rebooting you should have a brand new admin account. When you login as the new admin you can just delete the old one.
If this helps you resolve your problem, please
consider giving me a four rating .It will help me
as well. Thank you.
Nov 19, 2010 | Computers & Internet
Hi. I turn on the mac and the screen says Mac OS X then there is Name and password. How can I get in to the main screen?
If you do not know the password for the user, you can reset it very easily:
    Note
  7. Click Save.
  10. Click Restart.
Aug 28, 2010 | Apple aluminum 13-inch MacBook laptop-...
My mac will not let me log on!
Step 1: Start up from a Mac OS X Install CD. macosx-dvd.pngThis hardest part of this technique may be laying your hands on a Mac OS X Install CD when you need one. Use a version that is close the the version of Mac OS X you have installed.
Step 2: Choose Reset Password from the Utilities menu. resetpw-utilitymenu.jpg Tip: In previous versions of Mac OS X (10.2 and 10.3), you can find the Resent Password option under the Installer menu instead.
Step 3: Select your Mac OS X hard disk volume. resetpw-reset.jpg Select the user name of your original administrator account.
resetpw-passwordsaved.jpg Step 4: Quit the Reset Password tool, and Restart your Mac. resetpw-quit.jpg
Nov 18, 2009 | Computers & Internet
Mac OS X (iBook)
i think you will find this is done when the computer was installed i dont think you can change this without reinstalling the system. have u got start up disks, worth doing if you are the new owner any way n run
its like when u first put widows on it asks you for company name ha ha then it crashes
actionman
Feb 24, 2009 | Apple iBook G4 Mac Notebook
My daughter has a clamshell laptop and she changed her master password about 2 months ago and can not remember it. Is there anyway to reset the password?
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account (of several) needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, the original administrator user may reset the passwords of other administrator accounts using the steps described above.
  1. Start up from a Mac OS X Install CD (one whose version is closest the the version of Mac OS X installed). You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
  2. Choose Reset Password from the Installer menu (or Utilities menu in Mac OS X 10.4 Tiger). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
  3. Select your Mac OS X hard disk volume.
Set the user name of your original administrator account.
  • Enter a new password.
  • Click Save.
  • If you want your default keychain to be unlocked automatically when you log in, synchronize your Keychain Access and account login passwords by doing this:
    1. Open Keychain Access (you can get to it by choosing Utilities from the Go menu in the Finder).
    2. From the Edit menu, choose Change Password for Keychain "login."
    3. Type the former password of the account that you are currently logged in to, then click OK.
    4. If you entered the correct password, a new window appears; enter the original password again in the Current Password field.
    5. In the New Password field, type the password that matches your current account password.
    6. Re-enter the newer password in the Verify field, then click OK.
    In Mac OS X 10.4 Tiger, if you change your account's password using your Mac OS X Tiger Install disc (or if your network-based account password is changed due to a network admin forcing a password change), your default keychain password (which uses the same initial password as your user account) does not change. Because of this, you will be prompted to enter a keychain password each time an application requires authentication that your keychain would normally provide.
    I don't remember my original (former) account password If this is the case, you'll have to delete the keychain.
    1. In Keychain Access, choose Keychain List from the Edit menu.
    2. Delete the "login" keychain.
    The next time you log in to the account, you can save your current password in a keychain.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Dec 04, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
    A recent mac laptop with Tiger & bootcamp/win XP will connect to the internet via a Netgear DG834G adsl modem with ethernet cable in tiger & XP but only in xp with wireless. Any advice? JL
    If I understand you correctly you have an Intel based MAC, with the boot-camp boot manager, so you can choose to boot either from the native MAC OS or from Windows XP.
    The system works fine from the MAC OS, but the (wired) ethernet does not work from XP.
    1) When you boot into XP mode, the XP operating system is in
    charge and the MAC OS is dormant.
    2) Check the XP device manager to see if the ethernet NIC
    (network device) is properly installed and if the device
    drivers are functioning.
    From Windows XP:
    Right click My Computer ==> Properties => Hardware ==>
    ==> Device Manager ==> Network Adapters =>
    ==> Your network controller
    Right click on your network controller ==> properties
    Check the device status !!!
    2) If the device is NOT working properly, you may need to
    download and install a device driver for this card.
    3) If the device IS working properly, you may need to run
    the NETWORK SETUP WIZARD from the control panel:
    START ==> Control Panel ==> Network Setup Wizard ==>
    ==> Next.
    4) Assuming you are connecting to DSL with a login password,
    use the: "My computer connect to the internet through a
    modem" option.
    If your DSL is always on, or if you use a local router to
    connect to the DSL modem (the router does the work)
    Then you choose the: "My computer connects to the
    internet through another computer or a residential gateway"
    option.
    Martin
    Apr 22, 2008 | Computers & Internet
    Apple iBook G4 Mac Notebook Logo
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
