Question about NetGear WG111 802.11g/b Wireless Adapter
Can't connect to wifi.
Working on Windows Vista. Shows I have a connection, but won't allow me to connect to internet.
  • 724 Answers
Need to set the NOC and DHCP in the router
To get an IP and submask for your computer
IPCONFIG execution and do a renew
Posted on Aug 03, 2009
Im using a 2Wire Gateway DSL connected via ethernet to a Mac G4, I also have a laptop running windows vista and it has strong wi-fi connection, sending packets at optimal levels and speed. BUT Problem
Vista has a well known flaw of not allowing you to easily change access rights after selecting "public network" in the initial network connection screens. The easiest fix is to change the name of your wifi access point, reconnect, and be absolutely certain to select "home network" when the prompt comes up.
The best solution however is to ditch that crummy excuse for an operating system and upgrade to Windows 7 or 8.
Oct 05, 2014 | Computers & Internet
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
Satellite c655d-s5200: will not display available wifi connections
The RAS PPPoE driver file "raspppoe.sys" found under c:\windows\system32\drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system.
Feb 12, 2014 | Toshiba Satellite Computers & Internet
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I have installed a Netgear WNR3500U router on my home network. My Windows 7 WiFi laptop had no trouble finding the router, connecting, and accessing the internet. But our Windows Vista WiFi laptop can...
Check firewall settings in vista, might need to create exemptions to allow access. Check Antivirus settings in vista, might need to create exemptions. Quick test is to switch off both antivirus and firewall in order to establish connection. Also check if there is a newer wifi driver for your laptop.
Jan 15, 2011 | Computers & Internet
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
Says I have an excellant connection - but will not connect to the internet
same problem. the network shows up in the connection list, has max wifi signal, password was not rejected, and still the cursor/icon just spins indefinitely and never connects. I have Dell laptop with windows vista using the newest Verizon Fios router.
Dec 23, 2010 | Trendware WIRELESS AP TRENDNET|TEW-637AP R...
Cannot turn on wifi on T400. Intel 5100 card
Is the "broadcast-tower" light on (the leftmost icon on the lite-bar below the screen)? Have you got an available/working WiFi router? Have you been able to choose a network to connect to? My T400 works fine when all the above are enabled..
Jun 18, 2017 | IBM ThinkPad G41 Notebook
Windows vista laptop lost connection to the internet
Start off simple. Try a different port on the router. If that doesn't work, try a new cable. If that doesn't work, go to the Device Manager in Windows. (Right-click My Computer, select Manage, go to Device Manager). Does the card look okay? Has it been disabled or need a driver update? If we're still looking at issues then I would take a look at your router security. How many DHCP licences do you allowed to be assigned? Also do you have security in place (WEP/WPA, Mac Filtering, SSID Broadcast)? If you are light on security and only have a few assignable DHCP licences, you may have neighbors leeching your internet access.
To clarify: DHCP assigns a network IP address to each device on its network. Most Linkys routers have a default of 10, you may have reduced this yourself. If you have, you've limited the # of devices allowed on the network. So if you have 3 DHCP licenses available, and a couple neighbors are leeching, your Dell may not get assigned an ip.
If you still need further help, let me know.
Jun 24, 2009 | Linksys Ultra RangePlus Wireless Routr...
How to connect internet from other laptop
If you are connecting to a WiFi Access Point from one laptop, and you know the encryption settings and the SSID (name of the WiFi connection) then you can plug that infomation into your other laptop WiFi connection page and you should be able to connect.
The configuration is very similar to XP.. you just need the information to put in on the Vista..
DG
Dec 26, 2007 | Motorola Mobility A1200
NetGear WG111 802.11g/b Wireless Adapter Logo
156 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
