Question about Acer Aspire 5100-3357 Notebook
Expresscard problem I pluged in my sound Blaster expresscard and i got no power? Im wondering if the computer just has the port but it doesn't work or the card is bad?
  • 5 more comments
  • kawzx9r2001 Feb 24, 2009
    The computer works fine but when i slide the card in the power light doesn't come on and the creative labs program says the the device isn't found. there's no power button on the card or nothing like that? I didn't know if had to go in the computer so how and turn it on or what. I hate to think that a brand new card would be bad, but probably could happen?
    yeah, everything on the box of the soundcard fit's with my computer. I've never used the slot before so i didn't know if they had to be turned on or something like that would just show power right when you plug it in. Guess i'll head up tomorow and get another one and see what happens. Thanks for your help
    no that would be something that i have never done before. by all means please explain. im running widowns vista if that makes a difference?
    so i need to get into the computer setup when the computer is starting up and look to see if i need to turn it on there?
    I found nothing in that setup for turning on such a device or port?
  • Roberta Smith
    Roberta Smith May 11, 2010
    yes it can happen... be that as it may you already have the correct driver for the operating system you are using ?
    also you need to check the compatability of pcima card to the computer you have
  • Roberta Smith
    by no power... you mean it won't even boot up or the card isn't working ?
    Brigadier General:
  • 5,158 Answers
If you know how... look in your bios to see if the pcima port is on if you don't ... ask me
Posted on Feb 24, 2009
  • 1 more comment
  • Roberta Smith
    Roberta Smith Feb 24, 2009
    go to http://global.acer.com/support/download.... and download the manual for your computer.... what you need to read up on is "entering setup" or entering bios
    do NOT change any setting other then turning on the PCIMA port
    Robert
  • Roberta Smith
    i'll have a look give me a few minutes
  • Roberta Smith
    To activate the BIOS utility, press during the POST; while the notebook PC
    logo is being displayed.
    Have a look in there... the manual is basically useless...
Tip
How to Install a ExpressCards into your laptop
When we enjoy a weekedn with our family and shoot many pictures. We want to store it in our laptop battery and share with any other friends with email. We use the ExpressCard to connect the camera memory card with the laptop. Also ExpressCard plug-in hardware available includes TV tuners, mobile broadband cards, FireWire 800 (1394B), Serial ATA external disk drives, solid-state drives, wireless network interface cards, TV tuner card common access card (CAC) reader and soundcards. Media remote control units are available that use the ExpressCard slot to store and recharge battery4.us. So we must at least know how to remove and install a ExpressCards.
How to remove an ExpressCard or Blank
Inface removing an ExpressCard is a very easy thing. You can complete it only by two steps:
1.Press the card or blank to remove it from its slot.
2.Save a blank to use when no ExpressCard is installed in a slot. Blanks protect unused slots from dust and other particles.
How to install an ExpressCard or Blank
You can install Express Card while the computer is running. The computer automatically recognizes the card.
ExpressCards are generally marked with a symbol (like a triangle or arrow) or specify a label, which end in the slot to connect. The cards are keyed to prevent incorrect insertion. If the map orientation is unclear, consult the documentation that came with the card.
To install an ExpressCard:
Keep the card shows the top of the card facing up.
Insert the card into the slot until the card is fully engaged in the port.
If you encounter too much resistance, no force. Check the card orientation and try again.
The computer recognizes the ExpressCard and automatically loads the appropriate device driver. If the setup program tells you to load the drivers from the manufacturer to use the media that came with the Express card.
on Aug 03, 2010 | Computers & Internet
Need drivers for PCI-E expresscard 1/0 adapter
Go to www.drivers-download.com and search for DL-0254103 from "Drivers Search". Or you can use an alternate site: www.prolific.com.tw Use this path: Download >> USB to Port Controllers I/O >> PL-2303 Software and Drivers.
Jun 22, 2012 | Port Designs Best Connectivity RS-232...
I changed my PC and the new one has not the firewire port, only the usb. therefor i cannot ude the cable firewire-firewire that i used im my camcorder nv gs 150. I bougth a cable firewire-USB, but te +c...
I weould try using an Extgernal Drive with both USB and Firewire ports. Connect the camera to the firewire port and the USB port on the external drive to the computer. Not the most elegant solution but will most likely work.
If your computer has facility to add a firewire BUS then you could add one. Usually a blank port called express card 34.
See here for examples: http://www.synchrotech.com/products-expc/expresscard-firewire_00.html
Jun 11, 2011 | Video Cameras
Need to purchase and install a sound card for MD26 laptop
Here are a list of sound cards you can add to your laptop. Make sure it says ExpressCard Type 54 and it will be compatible. Also check for your operating System (I.E. Windows 7) compatibility.
http://reviews.cnet.com/sound-cards/creative-sound-blaster-x/4505-9334_7-32473759.html?tag=mncol;lst
Apr 13, 2011 | Gateway MD2614u Notebook
Do external HDDs with both eSATA and USB require both to power up?
No, one or the other.
I wondered too, when my new eSATA external disk did not work with my laptop.
If you have a faulty eSata connector into your laptop the eSata won't work at all, but you can probably still use the USB until you can get a better quality eSATA expresscard / PCI connector. I think the standards have changed and an older eSATA expresscard won't do the job with modern laptop and disk.
Aug 04, 2009 | Acomdata Samba USB Enclosure Kit Red IDE...
Hi i want to install grafics card in my laptop
do you want to install the driver for the card that is already in the Laptop?
Or are you looking to install a new hardware graphics card??
Because this is close to impossible for laptops.
Do you have an expresscard slot? It might be possible to get a card for something like that.
Its not a good idea but Asus introduced a graphics card for laptop expresscard slots.
I dont know what it costs (im sure tho that its way too much)
its called ASUS XG Station and you will be able to plug in a pci-Express graphics card.
The problem is: The Expresscard slot is only 1/16th as fast as the starndard PCI-e graphics port in a desktop computer. so plugging in a nice card will not result in great performance unfortunately.
as I said its possible, but highly inefficient, wouldnt recommend it.
Jan 29, 2009 | ATI TP T42 Notebook
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Acer Aspire 5100-3357 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
