Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under that round plastic plate inside the unit on top
  • llangston3 Feb 24, 2009
    is the fan under the round plastic cover inside does the cover just pop off and then change the fan or how thanks
    Brigadier General:
  • 8,619 Answers
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Posted on Feb 24, 2009
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    The fan is used to cool the magnetron during cooking, and because this fan is not working the mag is overheating and the thermal protector is opening, killing power to the unit, until it cools back down. All you need to fix this is a new fan blade. The fan blade is slipping on the motor shaft ( the noise you are hearing). The new fan blade fits tighter to the shaft to prevent this from happening again.
    There is your vent fan, and there is the magnetron fan. The magnetron fan blade is the bad one. You can look behind the control panel, remove the vent cover, take out the 1 screw at the top of the control panel. Push up on the panel and it will come off, and you can see the fan there. I replace the fan blades with the control off, kinda tricky though. Or you can remove the M/W remove the outer casing and do it that way. You do not need to replace the magnetron. and yes the fan comes on when you press start. Drop the control panel down and program to cook, and watch the fan blade.
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 microwave suddenly didn't work. All buttons on the front panel except "Clock" don't work. Open the machine, shorten the thermostat, the vent fan runs automatically....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL1800 The microwave runs, the lights come on, timers goes, but it does not heat/cook and it makes a loud buzzing sound.What is wrong with it,and can I repair or trouble shoot it?
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 29, 2010 | GE XL1800 1100 Watts Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
Spacemaker XL1800 runs but doesn't heat.
I think you should check the fuse first that runs the magnatron if the fuse is good that means the magnatron is bad! but if its only the fuse then you save time and money!
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Strange rattle when microwaving
Chances are the blade assembly has come loose on the shaft of the internal cooling fan.
This can be solved with a couple of drops of super glue at the spot where the blade and shaft meet, then allow it to dry for several minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll see the cooling fan.
Please let us know what you find.
Dec 23, 2008 | Sharp R-1490 Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
XL1800 still works fine but makes a lot of noise while on.
It may be the stirrer in the ceiling area.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,219 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
