Question about Kenmore Oasis HE 27082 Top Load Washer
We have a Kenmore oasis washer model 110 27062601 that does not rinse the clothes properly. You can rinse then twice and the clothes still come out with soap scum on then, the black clothes are really bad. We have cut way back on the amount of soap and it doesn't seem to make a difference. I think there should be a law suit for the performance of this machine. Help!!!!! 907-243-8566
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Will not complete cycle.
washer will not rinse clothes coming out very wet.
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The washer says f1 and wont rinse clothes so how can i reset it
washer fills but will not drain or spin!! should agitator spin seperatly from drum??? mine will not move!!
Jun 07, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Bleach spots
Likely the washer bleach dispenser - closing early - or the door has warped - so it does not shut all the way after the call for bleach.
You'll need to inspect the bleach tray - and make sure it operates normally.
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Apr 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Clean Cycle
I had the same problem. After unplugging and plugged it in several times, I got it to switch to a wash cycle. But now it beeps every 20 seconds.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
136 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
