Question about Acer Aspire 3002LCi Notebook
Installing new Acer Aspire 3200LCi Hard drive
I have repeatedly attempted to install a new 40GB hard drive into my Acer Aspire 3200 LCi. The Bios seems to not recognize it at all and do not know what to try next.
  • jef1162 Feb 24, 2009
    I tried that and it still did not work.
  • 43 Answers
You need to check that wheather you acer laptop is supporting the 40 gb hard drive.
check the compatability(RPM|)
and tell me is that external HDD or internal HDD.
Posted on Apr 02, 2009
  • Acer Master
  • 1,800 Answers
Try the jumpers set its th masterand slave thing
Posted on Feb 24, 2009
  • Jalal Sordo
    Jalal Sordo Feb 24, 2009
    tdoes the HDD Tested and OK??
    Also make Sure of The IDE Belt
    alsocheck if the bios is not enabling secondary ide hdd
Have reached the limits for my hard drive Can I fit a larger hard drive other than an external unit
Yes you could, but check your specificaion to see what the maximum size hard drive the BIOS in your laptop can support.
By installing a new hard drive, you need to install Windows on this hard drive, together with the Acer Aspire's device drivers, your programs and your data. This is a lot of work and time.
If it was me I would add an external USB hard drive and copy my data to this external hard drive.
The advantages of this method besides not having to re-build your laptop, you can exchange data between computers without the need to take along your laptop, you only need to take your external USB hard drive.
Nov 28, 2010 | Acer Aspire 1690 Notebook
I just bought a acer aspire 5315 from a yard sale and was told the hard drive was bad. i went and bought a wd scorpio blue 250gb sata hard drive. after installing it i put in my windows xp disk to format...
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Sep 27, 2010 | Acer Aspire 5315 Notebook
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
Removing Vista and installing windows xp
Before you attempt it, make a couple of changes in the BIOS to hopefully work around a few problems that might crop up.
"BIOS setup (f2) and set the hard drive to ATA compatible."
I would go ahead and disable everything in the boot heading besides the DVD/CD.
You also need to disable caching module before you change the drive SATA settings.
Jun 17, 2010 | Acer Aspire 5315 Notebook
My acer aspire when start up says no operating system what can i do I don't have any disk for my laptop
Can you go into your BIOS and see if it lists your hard drive? It looks like it is not finding your hard drive for some reason, could be a bad boot sector or bad connection. Unscrew the hard drive and re-seat it into its connector. You may also try pressing ALT+F10 (repeatedly) as soon as you power it on which should get you to the Acer Recovery Console to re-install Windows.
Feb 27, 2010 | Acer Aspire 3680 Laptop
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
Acer 3680. only half of the harddrive works.
check it on the bios the size of your hard disk, if its 80 gb then go to the control panel after booting open the administrative tools, open computer management, then select disk management, check the hard disk there, if there is an unpartitioned space , then convert it to the partioned space
Nov 09, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3002LCi Notebook Logo
211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
