Question about Whirlpool GS5SHGXLS Side by Side Refrigerator
Water runs out the water dispenser instead of filling the ice tray
  • 700 Answers
You need to turn around the wires for the solinoids that are in the back oif the unit.
Posted on Feb 24, 2009
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
My fridge sterted to pour water from water dispenser instead of filling the ice tray.
There are two possible problems here. Either the water valve is going bad on the machine, or even more possible the main controla board, located on the back of the machine and can't be located by the silver square plate the covers it. Unplug the machine and remove the plate and look for any signs of burns or major discloration. This board controls everything on the refridgerator. A good place to order parts from is www.repairclinic.com because of their awesome return policy.
Apr 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I just installed a new ice maker and the tray doesn't fill with water, but the ejecter cycles. Water dispenses at the door.
i dont think its getting cold,, if the ice tray is full of water but not making ice try turning up the thermostat ,,,but if no water it reaching the ice tray then its a fult in that part
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking through ice maker
check out the temperature inside of the freezer your probebl going to have to clean the condenser coiul underneith the unit
May 23, 2009 | Whirlpool ES5FHAXS Side by Side...
LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Jan 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool GS5SHGXLS Side by Side Refrigerator Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
