Question about Kenmore 24032\24036 Top Load Washer
Washing machine has low flow and stops in middle of cycle
My washer starts out fine, the water flows well. Then all of the sudden it will come to a halt, usually during the rinse cycle. I have to push the starting button in and out a few times to get it to come back on. When it comes back on the water flow is really slow and it takes forever to rinse. Most of the time I have to repeat that step a few times for it to complete a cycle. Any help would be great!!!
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 14, 2010
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
Knob won't work
Easy check for water filling problem like yours. Unplug the power and see if water still flows into machine. If yes----your inlet valve on the washer is stuck open and needs replaced. It is the part on the washer back where your fill hoses attach to. If the water is flowing into the machine while plugged in and it stops when unplugged, you have something in the control panel sending power to that inlet valve even when the machine is off. You would now need to find out where the power is coming from. If its an electronic control washer, the main board may need replaced.
Apr 11, 2015 | Washing Machines
The washer stops in the middle of the cycle and says IE.
The IE error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged and by removing the inlet hose from the machine, check that the inlet filters are clean. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Sep 09, 2014 | LG Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Washer continures to fill up with water to the point of over flowing and won't start a cycle
is most probably the inlet valve at the rear of the machine where the inlet hose connects too.
May have to remove the rear panel to gain access to valve, it may just be a wire has come off
Hope this helps
May 22, 2009 | Zanussi ZWF1430W Front Load Washer
Over flowing washer
If the water valve not getting 120 volts and its start filling that means its bad water valve if its getting 120 volts bad timer
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
66 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
