Question about Cozy Heating & Cooling
I have an outside vented wall mounted heater.It heats the room and before it shuts off the room gets as cold as when it started running.does that make sense?
  • Paul Carew May 11, 2010
    no it does not , once the room is up to temp it should stay there
    Problem Solver:
  • 10 Answers
What you might be hearing is the fan before it shuts down, the burners quit long before that. You might have a sticking fan switch thats letting the blower run to long and blowing cool air. You didnt say if your unit has a blower, I have to assume.
Posted on May 05, 2009
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
All pvc pipes frozen
1. insulate them well
2. if against outside wall, insulate wall.
3. heat the room with a portable heater as a temporary measure.
4. check for cold draft coming into the room.
Dec 08, 2013 | Plumbing
Installation instructions for house
if this is what the problem thing says it is then this type of water heater requires a special instaliation ,the room its in must be ventilated with permant vents through to a outside wall ,then a special valve in the flue pipe to prevent blowback down the chimmney also another valve in the flue to shut off heater in case of a partial blockage liuke a birds nest .If you are not sure of exactly what to do and the security and safety measures that go with this type of heater then get a plumber in unless your mounting it outside in a roofed over space with no sides like a porch .
Dec 25, 2011 | Bosch ProTankless GWH C 800 ES LP Tankless...
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Dec 16, 2010 | Desa International GWP20T GLOWARM Wall...
My wife want's to move the furnace to an inside wall. It is presently mounted to an outside wall venting directly outside. where she wants to move it is directly under an old flu for an old heater. can the...
it can go up but is designed to go up wall cavity and unit i supposed to sit with it's back against wall to adapt to a flu that is already there would mean you would have to sit out into room a little bit which could look funny, the only way i can think to do this and look good would be to make a false wall for flu so upou don't see it and it wouldn't have to be built to far into room only far enough to hide flu i would stringly recomend someone to come have a look at it for you as it is acchievable but to make it look half descent if not immaculate job would be to get a specialist on fluing to look for you and advise on options to get it to go to old flu outlet may be something you can do but i don't think it would be a good idea as you would have to either bring heater far enough forward to go straight up it as wood heater flu would have been a fair distance of wall for clearance's, or the other way would be to bring flu behind heater then elbow out to get over to old flu exit, so get someone to look at it for you as you want to also put into a place where it will heat efficiently too!
Nov 23, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
I Have A Cozy Space Heater And It Will Work For Awhile Then Goes Out, Relight The Pilot It Stays On Turn The Heater On And It Will Work Awhile Then It Shuts Off Again
if you have the vent pipe in a chimmney or vented outside wall can cause this problem, need to either put a liner in chimmney or vent insde the room with the heater up thru the ceiling.
Oct 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
Our chest freezer is as cold on the outside as it is on the inside. this makes the room very cold. It is a whirlpool freezer and is 15 years old. do we need to buy a new one?
No refrigerator/freezer can make a room cold unless it vents the heat outside that room. If yours really does make room cold without venting heat outside of the room, I'll buy it from you for $100000 and become too famous to post here ;))) What you describe here is against the physics laws ;)))
Dec 17, 2009 | Washing Machines
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
71 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
