Question about Kenmore 67082 Electric Dryer
Dryer buzzes I have a Kenmore dryer that buzzes for a short time before it starts. This happens everytime I start the dryer.
  • 70 Answers
Chances are the start winding in the motor are failing.
Posted on Feb 24, 2009
Kenmore dryer model 110.66722692 won't start
does the drum travel up and down losely. if so the spindle at the rear of the drum in the centre has worn and needs replacing
Dec 21, 2011 | Kenmore Dryers
My Frigidaire dryer (Gallery series) will not start. It makes a buzzing noise every time i pres the start button.
This is a indication that the motor had shorted out to ground and everytime you press the start button the start and run windings of the motor are grounding out. You'll need a new motor for this fix.
Dec 14, 2010 | Frigidaire Electric Dryer
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Kenmore 65942 Electric Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
My Kenmore gas dryer stopped in the middle of the time. When I pushed the start button, it buzzed, but the dryer didn't start. I waited to make sure the dryer hadn't overheated, and then I pushed the start...
sounds like the mtor over heated and stalled out . it will do it again . best to delint motor this will help to keeeep it cool and may prevent a lint fire . mm
Dec 03, 2009 | Dryers
On my kenmore 90 series dryer the barrel won't turn
most of the time when that happens it's the dryer motor getting weaker and weaker until one day it just stops and then all you will get when you push the start button is a buzzing sound,i see this all the time on kenmore"s-mike
Apr 22, 2009 | Kenmore 62602 Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Kenmore 67082 Electric Dryer Logo
104 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
