Question about Acer Extensa 5420-5687 Notebook
Acer screen ''jumps''
The screen jumps and closes programs. Right now, it will not stay connected to the wireless network though another laptop in the house does. Internet explorer randomly closes and has to re-start as well. HELP!
Acer aspire 4250 wireles problem (may due to adapter setting.
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access. - for-acer-users
Windows 7 Acer AspireLaptop wireless
Wireless Internet is a convenient way to hook up multiple computers to one router without the mess of cords.
The router or 2-in-one (router/modem combo), must be set up through your Internet Service Provider and connected with either a DSL line or Cable.
Since most Acer laptops have built-in wireless, no additional hardware is required.
Turn on the laptop.
Move the switch located on the front of the laptop to the right, then let go.
The switch will go back to its original position.
Confirm that the wireless networking icon has appeared on the screen.
Right-click the wireless icon in the bottom right corner.
In Windows 7 this will resemble a small stair-step triangle; In Vista it looks like a tiny monitor.
Click "View available wireless networks."
It might also say "Open network and sharing center."
Wait while the adapter finds your wireless network.
Click to highlight the network and click the "Connect" button.
Enter the security password that you created when setting up the router (if applicable).
If you don't know or can't remember, log in to the gateway page specified in the user's guide.
Locate the "Wireless security" settings page to see if security is enabled.
If it is, type in a new key and enter the same number for the wireless network.
Feb 19, 2014 | Acer Aspire 4520-5582 Notebook
532h wireless
The Acer Aspire One is an inexpensive laptop computer that runs the Windows operating system. The computer does come with a built in Wi-Fi receiver, giving you the ability to connect to a wireless Internet network, when available.
However, if you are having trouble connecting to a wireless network, you must troubleshoot the network connection to determine exactly what is causing the problem with the Internet.
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((ยท)))
Make sure its pressed on.
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network."
You will see a list of available wireless networks.
Wireless Acer laptop can be a massive boon to your productivity when it is working properly and a massive headache when it is not.
When your laptop card begins to exhibit undesirable symptoms, such as signal dropping, you can avoid a hefty repair bill by performing at-home troubleshooting.
The best solution is to merely reinstall the software driver, which refers to the program that the operating system uses to speak the wireless card's language.
Open your operating manual and look up the model name and number for your laptop.
Navigate to the Acer Support web page (see Below) and click on the "Downloads" link.
Input the model number of your laptop, click on the "Search" button, download the wireless driver file for your laptop model and save the file to your desktop.
Open the "Start" menu, click on "Control Panel" and open "Device Manager."
Open the "Network Adapters" menu, double-click on your wireless card, select the "Drivers" tab, click on the "Update Drivers" button and choose the desktop as the location to search for new drivers.
Click "Next" to reinstall the driver, fixing your wireless woes.
Apr 27, 2013 | Acer Aspire One PC Notebook
Wireless lan not working on my acer aspire 4520
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
1.Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
2.Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
3.Select the network you want to connect to and click "Connect."
Sep 07, 2011 | Acer Aspire 4520-5582 Notebook
I have acer aspire 3000 laptop using xp and ie cant get wireless working tried button in front lights dont work or nothing comes up on screen saying enabled or dis abeled
Have you installed the necessary drivers for the wireless adapters? If yes, please check in the Network Connections if the wireless connection is enabled or disabled. Also, check if there are other programs using the wireless connection like Realtek Wireless LAN Utility.
Apr 06, 2011 | Acer Computers & Internet
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
When I double click on the Wireless icon and try to connect to my wireless router, the network card tries to "acquire a network address" but the speed jumps from 65.0 Mbps to 150.0 Mbps and back...
Silly question but have you had to put in a password code or serial no at all ????
try this
go to the wireless icon on your taskbar bottom right
click on it to open the box that says wireless network connection status
go to bottom left of that box and click properties
now go up to wireless networks
now click on the name of your router that it is having problems connecting to
right click on it and go down to remove it
now close the two boxes that are now on your desktop
and in a few seconds windows will show you a small box by the wireless icon in taskbar bottom left of your screen telling you that wireless connections are available
open the box again go to the name of your router click on it and go down to connect
hopefully this will fix it
i hope so
good luck
Jan 30, 2011 | Acer Aspire One D255-2670
I am trying to set up Wi-Fi from my acer notebook to my new stereo, could you please send me a network sercuity key
hi there!
The Acer Aspire One is a miniature laptop that includes many of the same features larger laptops have. The Acer Aspire One is about the size of a diary and features an 8.9-inch LED LCD display, an 84-key keyboard, two built-in stereo speakers and Wi-Fi capability. Though smaller than most laptops, the Aspire One functions much like other computers. The Aspire One uses the Windows operating system, so it connects to a wireless network the same way that any other Windows computer does.
  1. Click the "Start" menu in the bottom left corner of the screen.
  2. Click the "Connect To" option from the menu that appears. The "Connect to a network" screen will appear.
  3. Click on one of the networks listed on this screen to select it.
  4. Click "Connect" at the bottom of the window. You now have set up a wireless connection on your Acer Aspire One.
The network security must be established by you.
Hope it helps,
Nov 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire Wireless Connection
lets start with reinstalling the wireless drivers / software on the laptop.
open device manager by rightclicking my computer and select manage.
on the left side select device manager
then on the right side, find network adapters, open it from the + mark
right click on the wireless adapter and select uninstall. Then restart the pc. The wireless will be reinstalled when you start up the pc again.
See how your wireless works, if there is no change go back and right click on the wireless and select properties, then click on the drivers tab. and click on update driver, let it look for a update online if asked. if it doesnt find a update
you can get the newest wireless driver from acer at this website
May 13, 2008 | Acer Aspire 5050 Notebook
Acer Extensa 5420-5687 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
