Question about Toshiba Tecra 730CDT Notebook
I have the 1997 tecra 730xcdt. The battery has completely died. when i would plug it in the battery icon would come up and say i need to replace the battery. When i moved, i missplaced the charger cord. Where would i find a new charger cord and battery?
Tecra satelitte will not turn on, orange light flashing, what sould I do
Sounds like your battery is dead. Remove the battery and plug it up does it come on?
Feb 18, 2015 | Toshiba Computers & Internet
How do i recover toshiba tecra 730xcdt windows password?
If a user account needs to be reset, logon as the administrator or as a user with administrative access, and then follow these steps:
Click Start, point to Programs, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
Expand the Local Users And Groups object under System Tools, and then click the Users folder.
In the right pane, right-click the appropriate user object, and then click Set Password.
Type the appropriate password, and then click OK.
Click OK to acknowledge that the password change succeeded.
Close the Computer Management console and Administrative Tools windows.
The user can log on with the new password.
To Reset the Administrator's Password
Log on to the computer as a user with administrative privileges, and perform the steps
listed above for the Administrator account.
If the Administrator password needs to be reset, and there are no other users with administrative access, there is no way to recover the password and the operating system will need to be reinstalled.
or if you have not set a bios password
restart your computer you will see on your screen to press a certain key to enter bios usually the Delete or the F2 key
press and hold that key to enter set up BIOS where you can set or remove your password
this will differ depending on you computer and bios
hope this helps
Aug 08, 2012 | Toshiba Tecra 730XCDT Laptop AC Power...
How to disable bios password on toshiba tecra A11-15Z laptop
dear sir "
this is not a just password this is a supervoiser password of toshiba tecra a11 please give me a stronge solution of this cheap password .
Apr 23, 2012 | Toshiba Computers & Internet
1997 Suburban. Turned on headlights and truck completely died
under the hood there is a fuse box with a 50 amp fuse in it this may need to be replaced
Nov 14, 2009 | 1997 Chevrolet Suburban
My Tecra Toshiba will not turn on or off, even plugged in.
Yes it is. And, it is highly recommended that you remove the battery if you're going to use your laptop for more than 1 hour. If you keep your battery in and have the laptop connected to the adapter, the poor battery is going to be charging/discharging so much that its life is greatly shortened. Also, this is what causes dead cells in batteries.
You might possibly have an internal power supply problem.
But, go ahead - remove the battery. See if it helps.
You also might try letting the battery charge for 3 hours with the laptop off.
Oct 12, 2009 | Toshiba Tecra A1 Notebook
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
Coke spilled on laptop,light flashing on front (orange) with symbol of a 2 pin plug
Hi...
Take the battery of the laptop, let the coke dry completly and then only start the computer...
If no go ...
The motherboard need to be replaced.
Thanks
Smith
Jul 12, 2009 | Toshiba Tecra M1 PC Laptops
Have a used Tecra 730XCDT
I might have an owner's manual in pdf format but it's on floppy. I'll be working on my broken Tecra 730XCDT which means transferring data from the hard drive. The manual should be in those files too. I'll contact you and send you a copy. Bear with me for a few days on this.
Dec 02, 2008 | Toshiba 730XCDT Notebook
Toshiba tecra m2 laptop wont start..
nothing happen when you press power? and when you plug energy no led?
Aug 27, 2007 | Toshiba Tecra M214-XGA (PTM20U0776X7)...
Toshiba Tecra 730CDT Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
