Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 will not charge. I tried pressing the reset button under the faceplate. Any other suggestions?
  • 1 more comment
  • khackett Feb 25, 2009
    same problem with no charge...
  • Anonymous Mar 06, 2009
    Garmin contacted me and said the battery needs to be replaced and that it should be sent in to do... going to have to buy another device...
  • venturescott Mar 16, 2009
    The C340 would not turn on except for a couple of seconds and then would go blank. Tired pressing the reset button, but now will not come on at all.
    This is after running it on the charger all weekend. I guess I'll try the USB cable tonight when I get home. Any other ideas??
How old is it? Could the battery need replacement ?Mine still works but the battery like has gone down to an hour.
Posted on Mar 06, 2009
Garmin c340 will not turn off and I cannot see a reset hole.
Your unit has a reset button under the faceplate. There is an indentation under the top of the faceplate. Insert your fingernail and gently pry it forward. Pull the whole faceplate off, and you will see the reset button on the bottom right of the unit. I hope this helps.
Jul 20, 2010 | Garmin StreetPilot c340 GPS Receiver
Screen froze
Have you tried resetting the unit?
There is a master reset button located under the front faceplate.
Try pressing it and holding for 2 seconds.
Hope this helps.
Jun 08, 2009 | Garmin StreetPilot c340 GPS Receiver
RESET BACK TO KANSAS AS HOME, I AM IN OHIO
Where did you reset it. I'm trying to find the reset button for my SreetPilot C340 but don't know where it is.
Aug 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 stop responding no sound, no movement at all - DEAD! Serial #116484764 Registration Code VADUCBQ
please leave the unit with out power for few hours and then again start the unit.
that may help you in some cases
Aug 12, 2008 | Garmin GPS
My Garmin c340 turns on then shuts off even when plugged in
I have the same problem. I have had it for only 4 months.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
C340
Try resetting the unit. There is a reset button under the faceplate. Carefully remove the faceplate with the Garmin logo with your fingernail or a knife blade. There is a reset button along the right side. I bought a refurbished C340 and it did the same thing right out of the box. The tech support people where I purchased the unit told me how to reset it.
Jun 11, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 06, 2008 | Garmin StreetPilot c340 GPS Receiver
My garmin c340, only a few months old just died--cannot get it to turn on and it definitely is not the fuse. Help!!
I took the faceplate off very gently starting under "garmin". I plugged it into the cig lighter in my car and turned my car on. I pressed the reset button and it turned on (THANK GOD!!). I then let it charge a little.
Mar 15, 2008 | GPS
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Will not turn on
Champ...If your 340 stops responding, try turning it off and back on.If this does not help, reset the 340.
1.Unplug the power and the usb cables to remove external power.
2.Place your thumbnail in the groove located under the Garmin logo on the faceplate and gently pull off the faceplate.
3.Press the reset button for about 3 seconds.
4.Connect the 340 to a power source using power cable. The 340 should automatically turn back on and operate normally.
Good Luck ... Ginny
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
114 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
