Question about Logitech Cordless Mouse
Where do I connect the transceiver
I have an HP monitor and HP tower. Where do I connect the transceiver? When I plug in my transreceiver it does nothing like my laptop is not even recognizing it. any suggestions?
    President:
  • 2,976 Answers
If it's a blutooth mouse, you have to co into the control panel and turn blutooth on. If you don't have it, you can download it from your computer manufacturers website. Get the correct blutooth stack for your machine.
Posted on Feb 28, 2009
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Aug 25, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Power saving mode upon start up
i) usually an computer enter's into power saving mode if computer monitor is not receiving any singals from the computer tower, so it has nothing do withur computer monitor(computer monitor is working fine), there is some problem withur computer tower.
ii) now try  removing all the physical connections going to computer tower(back side), wall socket  and replace them ....., (to avoid loose connections)
   now see whether ur computer is turning on and working properly so that your computer monitor receive singals ....
  let me know what is happening
Thanking you
M. Sridhar
Jan 01, 2009 | HP Pavilion a450n PC Desktop
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
NO POWER
Hmm. Well, that doesn't make sense, as your monitor should power on even if isn't hooked to the tower. I'm out of ideas.
May 06, 2008 | HP Pavilion 754n PC Desktop
Logitech Cordless Mouse Logo
35 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
