Question about Amana 25.9 cu. ft. Side-by-Side Freestanding Refrigerator SX26V
FILTER LIGHT WILL NOT GO BACK TO GREEN
INSTALLED NEW FILTER BUT LIGHT IS STILL RED.
  • gdegiovi Feb 24, 2009
    THANK YOU PEYTON I FOUND THE RESET & IT WORKED
    GDEGIOVI
  • 410 Answers
There is usually a filter eset switch you have to push to reset the filter monitor If you will post a complete model  number for your unit I will look it up and see exactly what you have to do to reset it. on most amanas there is a switch that you hold down for 3-5 seconds that resets it.
the light does not automaticaly reset when filter is replaced. Thanks Peyton
Posted on Feb 24, 2009
4 Suggested Answers
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Posted on Jan 08, 2008
  • 111 Answers
SOURCE: Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Posted on Dec 19, 2008
dniro592006
  • 121 Answers
SOURCE: Installed a new filter and pressed the reset
Sounds like you have a water valve problem
Posted on Oct 30, 2010
Pur fauct water filter light is red all the time .installed a second on same thing
every time when you install new filter you should cancel light .look on you use & care guide
Sep 02, 2017 | Refrigerators
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How to remove/replace the water filter
If the light on your refrigerator is green, you don't need to change the filter. If it's red, then it's time to change it.
Next, locate the filter knob at the base of the refrigerator. Turn it 1/4 to the left and then pull out the filter. Put in the new filter, then lock it by turning th knob back to the right.
Reset the indication light inside the refrigerator by pushing it 5 times within 10 seconds. The light should then turn green again.
Feb 21, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I installed the new filter but the red light is still on. What should I do to turn off the red light. Tks in advance
On the refrigerator side: Open the door and press the light switch in and out 5- times so you can reset the computer, do this quickly. If this fails, try unplugging the refrigerator for a minimum of 5-minutes. Plug unit back on after 5-minutes- this should reset PC.
Oct 05, 2010 | Maytag MZD2667HE Side by Side Refrigerator
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Changing light after installing new water filter
Water Filter Status Indicator Light
(select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the LOCK and WATER
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
131 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
