Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Why doesnt my jabra vbt 2050 aswer calls, it rings but when you push the ceter round answer button it goes to ignore and you cant answer the call?
3 Suggested Answers
  • 25 Answers
SOURCE: Lost instructions to my Jabra VBT 2050, how do I turn it on??
try holding call button down for 10 seconds on that one, it shold start blinking, than remove your thumb as soon as it starts blinking, to turn it off reverse the process, remember passkey is 0000 or 1234. good luck
Posted on Jan 25, 2009
kozachek
  • 122 Answers
SOURCE: need passkey for jabra vbt 2050
The default passkey for this headset is 0000. Hope this helps =)
Posted on Mar 21, 2010
SOURCE: Problem pairing my Jabra vbt 2050 with my blackberry storm
EUREKA AT LEAST I FOUND THE SOLUTION PAIRING VBT2050.
THE STEPS ARE ALL RIGTH BUT YOU NEED HOLD ANSWER BUTTON WHILE YOU ARE ENTERING 0000 PASSCODE AND DONT STOP TO HOLD IT STILL YOUR HANDSET ASK IF YOU WANT CONNECT VBT2050. YOU WILL SEE THE LIGHT ON FIRM OF HAND SET WHILE HOLDING.
I REPEAT WHEN YOUR HANDSET WAS ON DONT STOP HOLDING ANSWER BUTTON STILL YOU FINISHED ALL STEPS
Posted on Dec 15, 2010
Need passkey for jabra vbt 2050
Mar 21, 2010 | Jabra Radio Communications
I have paired my jabra vbt 2050 to my ps3 and turned on the connect option under manage blue tooth options but could not talk or hear my friend in a game???
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks......
Jan 26, 2010 | Jabra Bluetooth Headset with Adjustable...
I bought a jabra bt 2050...i cant get the led light to stay on..it only wants to flash...and it wont pair with my blackberry storm
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jan 05, 2010 | Jabra BT2050 Bluetooth Headset
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
Mar 04, 2009 | Jabra Bluetooth Headset with Adjustable...
How to tell if Jabra VBT is on or off.
o.k. when its on charge is there a light on? after complete charge the light is suppose to go off. to get it to go on again push the call button till the light does come on. at least 6 seconds and than take it from there, its suppose to go on and blink. discover mode is solid light. pass key is 0000 or 1234. dont give up its a neat machine and it just takes a little patience.good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
Jan 11, 2009 | Jabra BT350 Bluetooth Headset Headset
Lost my passkey for jabra 2050
the standard pass key for the jabra vbt 2050 is 0000.
it worked for mine
Jan 05, 2009 | Jabra Bluetooth Headset with Adjustable...
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
61 people viewed this question
Top Jabra Radio Communications Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
vimal
vimal
Ed Nelson
Ed Nelson
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
