Question about Dell E173FPc 17" TFT LCD Flat Panel Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
We have a Dell E173FPc monitor. The screen is black and the power button cycles between off, orange and green continuously. Any ideas? Thanks.
  • likearockz71 Feb 24, 2009
    It does the same thing, so I guess the monitor is defective. Thank you for the information.
    Scholar:
  • 135 Answers
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Posted on Feb 24, 2009
Will my dell tft show anything on screen if no input
Normally you can push the menu button on the monitor to look at menu options. If there is no input it will normally show that on the screen initially and they go into sleep mode.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell e173fpc Display Issue
Check if the cable connected to your monitor and video card is fix and secure.. Check also if the video card is properly seated in the motherboard.... Try to check using other computer if the video card is working..
If the test is all ok.. then the last option will be to check the backlight inverter of your monitor....To do this, you need to bring the monitor to a credible technician to have it replace..
much appreciated if you could rate this help..thanks..
May 24, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
My dell E173FPC monitor screen is black and doesnot show for more than 2 seconds although the green power button is on.
You have a unit with a failure in the backlight power supply. This is a common problem with LCD monitors after 2-3 years of use. Here is a link to an article we have posted that shows what needs to be done to repair the unit along with full parts list: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ If you can solder then you can do the repair yourself. If you don't care to do the repair we do offer a repair service for the unit, details can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
The Power button on my monitor keeps blinking...and I can't see what's on the screen..one moment is white..one moment is black..what should i do?
The Dell E173 series have several different versions specified with a third letter the end of the model such as e173FPb, E173FPc and E173FPf. The different monitors have different repair procedures but you should be able to do the repair yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm We have free step by step repair guides for several of the Dell monitors. Check the label on the back of your unit and check the corresponding repair guide for the instructions. If you don't see your model let me know at the email address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Dell E173FP 17" LCD Monitor
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
E173FPc LCD Repair
The color of the wires doesn't matter. That's just insulation. If you are able to see the screen then your backlights are working, which is what the wires you refer to are powering. The distortion is either because your new board actually does have a problem, or because when you attached the ribbon cables, you didn't get them on quite right. Try removing and reseating them.
Apr 17, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT LCD Flat Panel Monitor Logo
636 people viewed this question
Alun Cox
