Question about Speed Queen AES28AWF Electric Dryer
How do I reverse the door to open r to l
Brand new dryer Feb 2009- the door opens left to right and that doesn't work real well in the space I have
  • 70 Answers
You would need to refer to the user manual for that model. See IF it has the ability to change the door swing. If it does, it will tell you in the manual how to doit
Posted on Feb 24, 2009
Can the dryer door be reversed to open the opposite way on the 800 series Bosch?
it is possible . I suggest that you talk to a service repair shop to get details of how to to it if it can be done.
Feb 06, 2013 | Bosch Nexxt 800 Dryer
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
To reverse the door opening do I need a kit or can it be done just so.
These units are made to have doors to open on the left or right. You just have to look at the hook up now and repeat it on the other side to reverse the door opening.
May 15, 2011 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need to replace a belt on my hotpoint dreyer how do i do it
Disconnect power.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screws and raise the top.
Look down inside the open top dryer from above . If unbroken it should be showing across the tub from left to right. If broken you won't see a belt (about 3/8" thick). If belt is missing, proceed. On each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top. Take the new belt and work it over the drum from front by lifting and rotating the drum. Lay belt on drum about 1/2 way back from front with groves down on the drum and proceed to reassemble machine by reversing disassembly procedure.
When reassembling the top, part of each underside edge of the top must go beneath a sheet metal lip located at each right and left edge of the dryer just below the control panel. If the small space between the side and top panels is wider at the back than the front you have not accomplished this alignment, try again.
Once you have the top and front back on, pull out the dryer and remove the small access panel at the back bottom. The belt must be "looped" around the motor and idler pulley like this ( ). Slowly turn the drum around one turn to line up the belt, to make sure that it will not fall off because of being crooked or twisted.
Sep 16, 2009 | Hotpoint NWXR473GV Dryer
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Speed Queen AES28AWF Electric Dryer Logo
129 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
