Question about Whirlpool LER5634L Electric Dryer
Whirlpool dryer will not turn on, cant tell if it is getting ower or not, but this is the 2nd dryer to do this over the weekend, please help
  • Whirlpool Master
  • 3,361 Answers
With a volt meter check for 220 volts at the dryer outlet from the wall.
No 220 No dryer.
Posted on Feb 24, 2009
I need a manual for a Whirlpool Dryer.
Hello & Welcome to FixYa
Please get back with the model# of your dryer for the manual and please tell me what type of manual you need.
Kevin
Jun 26, 2011 | Whirlpool Dryers
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
My Whirlpool Duet electric dryer WED9400SW0 dryer turns on but when I push and hold the start button it won't start rotating. It worked fine all weekend and then today, nothing. Help??
heatman101
May 04, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Please, can you tell me how to tighten the belt on an Inglis dryer model J073500
Sorry for the troubles but you cant tighten the belts on those or any dryer for that matter. Here is the problem your belt is worn out and that's why it is loose and if you have replaced it and its loose you are installing the belt incorrectly around the idler pulley or have the wrong belt or your idler pulley is worn out. I hope this helps solve the issue your having and for instructions on installing the belt go to youtube and type in whirlpool dryer drum belt installation they will show you the correct way to do it and whirlpool builds your model dryer.
Jan 22, 2011 | Dryers
I have a Whirlpool Duet Dryer that indicates the "Control [is] Locked. The problem somehow began while I was away over the weekend and it no longer allows me to start the dryer. (I have a total of...
Hello
Your whirlpool duet dryer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer has very little heat
Sounds like your not getting enough gas supply,there is a regulater that controls the flow of gas they can get carbon build-up and restrict the gas.You need to turn off your gas supply and unplug it,remove the regulator and clean the lines,or replace the part.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Whirlpool LER3622HQ Electric Portable...
Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Jun 14, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer cutting off
You may have a lint build up coating the windings of the motor. Not knowing what brand of dryer you have, all I can tell you is that you can attempt cleaning the motor to see if it helps.
Please disconnect the dryer from its ower source before servicing unit.
May 27, 2008 | Dryers
Whirlpool Duet Electric Dryer Model Gew9200
Check the thermal fuse for problem here.Please leave a Rating! Thanx!
Apr 23, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool LER5634L Electric Dryer Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
