Question about Canon PIXMA iP4000R InkJet Printer
Cannon IP4000 PIXMA - pink & green streaks
Recently started having a pink and a green streak (about 1/4 " wide across the photo at end of printing. tried cleaning and deep cleaning - no help. Print check pattern fairly good - the pink and the blue strips have dark and light shades on them, but no definite white spaces within the color.
    Problem Solver:
  • 5 Answers
I've had the same problem with my ip4000, but the solution was to get a new print head. They can be quite costly, so I recommend the following:
1. Contact Cannon support and see if you can get them to send you a replacement. They sent me one free of charge, and didn't need an RMA for the old one, so it was hassle free.
2. You can always try to aggressively clean the head yourself by removing it and following some of the "home brew" procedures others have tried. However, you can damage the head further this way and it's only a last resort. Warm distilled water and a syringe was used by one person. When I tried this, it did not work at all, and I called Canon for the replacement anyway.
Posted on Feb 24, 2009
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
Pink and blue streaks on right side of page
most probably your "soak" pad need exchange. check your manual and change it. when you "deep clean" heaps of ink is absorbed into the pad exacerbating the problem, not solving it.
remove cartridges first and check them for existence of any foreign matter,
check for presence of debris under the head and parking place, remove if any,
i would suggest cleaning of printheads, albeit this can be risky (check first if your ink is soluble in water, isopropyl alcohol or methylated spirit, use that which solve your ink without clumping as cleaning agent), remove cartridges and allow appriopriate solvent to sit few second on metal rasters, wipe them with clean absorbing tissue and repeat procedure till solvent is "sinking" through the net.
remove old and install new absorbent pad under the print heads,
re-install inks, print rest page and then "normal" page. ink on first test page maybe very weak as solvent need to go through first.
if you follow the steps correctly, your should have clean print on the end.
"deep cleaning" is just waste of time, effort and ink. it is better if you create yourself a document with alternative lines of all three basic colours and black and then print it.
Jul 26, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Not printing full solid, lines, ghosting, streaking, often type is not even printed/unreadable
go to the printer control software on your pc and find maintenance or troubleshooting menu. select option to clean print head.
Feb 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Pink streaks across the photo
CCD image sensor chip is failing & requires replacing . Contact your nearest Service for quote. But probably more economical to replace camera with new one. Sell faulty one on ebay, its still worth money for parts :)
Aug 20, 2009 | Fuji FinePix A340 Digital Camera
I am getting black streaks on the back of the pages i print
Go into the driver from the control panel and do a bottom plate cleaning from the maintenance tab
Aug 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Refilling Cannon 106 cartrige streaks on page.
when you start using refill kits they messup you machine you will need to use the oem toner for the canon good luck canon sr tech
Jan 22, 2009 | Office Equipment & Supplies
Wide black streak on back of printed paper
it is not directly coming from the head. Probably you are printing your photos without borders. This means that the printer prints slightly beyond he paper. As a consequence is sprays ink on the mechanics and after a while it starts to smear on the back of the paper.
This phenomenon is even mentioned in the printer manual (kind of caution when selecting borderless printing).
There is a menu item in the printer utilities that lets you clean the printer mechanics with a folded paper. I tried this, but it helps only little.
I have the same effect on a pixma IP 4500 , and I live with it.
Dec 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Our Cannon MP 500 is leaving a 1/4" wide black streak on the back side of copies. I have cleaned off the cartridge heads, replaced the ink tanks cleaned the heads to no avail. What is the problem and how...
HI Foster,
The problem is not with the print head. Print a blank page and if you are still getting the streak. Something is probably trapped in the printer or the rollers are dirty.
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP4000R InkJet Printer Logo
217 people viewed this question
old marine
old marine
