Question about Maytag MMV4205 Microwave Oven
The microwave does not heat and the turn table does not turn
The microwave does not heat and the turn table does not rotate, all else seems to work. Previously, the turn table would turn when the door was opened. - GE microwave. Likely problems?
  • Anonymous Mar 30, 2014
    when I open the door of the microwave it start to heat
  • Maytag Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
Why food is not heating up fan is working and turn table is also rotating?
The heating up function is not working, so get it repaired or buy a new microwave.
Aug 26, 2014 | Microwave Ovens
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
Dec 21, 2010 | KitchenAid Microwave Convection Oven
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Sep 26, 2010 | GE JVM1440 Microwave Oven
Turn table
See the following suggestions from Repairclinic:
The carousel won't turnAlthough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
Oct 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Belling microwave
Turn table motor open circuit/drive shaft damaged
Oct 18, 2008 | Belling Microwave Ovens
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
check the connections on the h.v side because the unit works on 4500 volts and if there are any bad connctions it will not reach its working voltage and will not energize.remove all the connections 1 at a time and tighten all the terminals and try it will not be able to test the components with a digital multimetre as it does not have the need an analoge unit with a 10k scale and a 9 volt battery inside or it will give you falsr readings.teh diode which is thge little black unit with 1 side down to earth should read half way with the laeds on 1 way then when you put it on the opposite side it should not move.the capacitor will make the needle of the multimetre flick up when put onto the terminals both ways.the magnetron should have a short reading on the terminals but with 1 connected to the terminal of the input and 1 to the case it should not read at all,hope this helps regards les
May 15, 2008 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
205 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
