Antenna rotator motor failure?
I have a channel master 9521 antenna rotator and would like to see if the motor is still good. I do not have the controller for it. I would like to know the input voltage into the motor itself and possibly look at a wiring schematic for it so I know which of the three connectors are volatage inputs and which one is output or ground.
If the motor is fine, I can get a controller. If it is bad, I'll need to order a whole kit. I don't have money to waste and must make the right decision the first time.
Thank you for your help.
  • Anonymous Apr 07, 2009
    I've bought three similar units. One was bad out of the box (new from eBay!) Another failed after only a few months service. I've swapped controllers so I suspect the problem lies with the rotator motor and gearing up at the antenna.
    A local tech wants $30 just to check it out. With packages at $60, it hardly pays to fix them nor to continue to buy replacements!
SOURCE: GE RM24948 Code input prob
1. Ch (-) x #
2. Vol (-) x #
3. Ch (+) x #
4. Vol (+) x #
Hope that helps. Same thing happened with me and it took a while to figure it out. like 20 min. to try all combinations with all different codes.
Posted on Nov 27, 2007
  • 3 Answers
SOURCE: RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Posted on Mar 17, 2008
welcomejee
  • 10594 Answers
SOURCE: Backlight Inverter Input Voltage
input voltage like 21.4dc is correct and not sure about master or slave inverter board. You have to check one by one. Here is part store offers cheap prices for boards, please ask required boards.
Posted on Sep 06, 2008
mrwtech
  • 59 Answers
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
SOURCE: rca rcu600d universal remote
go screw your mom
Posted on Jan 06, 2009
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
My antenna won't rotate and I now receive only local channels
There could be a problem with the wires going from the control box to the rotator, or the remote itself
Good luck,
Marty
Apr 22, 2014 | Digiwave ANT-3045 Remote Control Outdoor...
Cannot get NBC on my channel master
Your signal strenght is too weak either try moving the antenna to a different location. If that doesn't work then you may need an outside antenna. The link below will tell you what stations are available at your address and what type of antenna is necessary.. TV Fool
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
The channel master locked up so I unplugged it. Now, when I plug it back in it just sits and says loading Chanel master tv but does not load. What should I do?
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the loading channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Sep 22, 2013 | Channel Master CM7000PAL HD DVR
CM7000 DVR keeps turning off and resetting when I try to enter My Recordings.
Feb 09, 2013 | Channel Master CM7000PAL
26" ILO digital T.V . won't pick up digital signals w/digital antanae.\r\nusing air in setup
So called digital antennas are generally a gimmick. The important factor to receiving stations is the antenna position and strength relative to the incoming signal. (Digital signals are either enough for the tuner or you get "no signal".)
Look at antennaweb.org or tvfool.com to find out what stations are likely to be received in your area and the direction to rotate the antenna; plug your address in the search area. Antennaweb is very conservative in its channel list even though it assumes an external antenna. Tvfool gives a list of the channels you should get with various antennas (labelled by color). This is a standard label that will be on the antenna specs or box (at least on good antennas). Tall buildings and trees in the area can reduce the channels you receive.
Adding an amplifier may help you gain signal strength for borderline stations (or if you split the signal to several devices).
I hope this helps.
(My house has an external antenna with an amplifier/splitter. Antennaweb suggested that we'd only get the stations from ~10 miles away. We get those stations and the ones from ~30 miles away with the antenna rotated for the further stations.)
Sep 11, 2010 | iLO 2600 Television
Rotor not turning antenna
Most rotors have a brake, if yours has one, you have to hold the brake down then rotate.
Jan 31, 2009 | Channel Master 9521A Remote Control
Open Questions:
Televison & Video Logo
331 people viewed this question
Top Televison & Video Experts
