Question about GE Dryers
How to get the 3 scew back in the dryer drum GE DRYER
I can''t line it up
  • 52 Answers
If you put your knee under the drum while your arms are inside the dryer, you can line up one. You could also duct tape one screw in and stand over the dryer to line it up. Then once lined up, manouver your foot or leg under the drum.
Posted on Feb 24, 2009
How do I remove the drum on my ge dcvh640ej0ww dryer
the top mat have to come off ..3 screwss from the back?to hold up the drum and rotat to line up the holes. good luck.
Mar 15, 2014 | GE GTUP240EMWW 24" unitized spacemaker no...
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
How you open side of dryer model GE DSXH 43 to clean lint from the motor
unplug it,take the top off,should be screws in the top back,then you have to remove the control panel,sometimes you can just leave it on top of drum or on the side of dryer,then remove screws that hold the front panel on,you can google your model number on utube and watch a video on it.you don't have to remove the drum if you have a shop vac, you can vac up all the lint you see,then set the vac up to blow and blow all the lint from the back to the front so you can vac that up and clean out where the lint filter slides down into,then go in the back remove the vent line and you can use a leaf blower to blow out the line,usually takes 40 to 60 minutes depending on how dirty the dryer is.
Jan 09, 2010 | GE DSXH43EF Electric Dryer
I have a problem with my dryer, it is leaking water from it, was wondering where it might be coming from, any suggestions? I just dried a load of clothes and notice some water leaking from under the dryer....
all the dryer does is move air,if the steam can't move to the outside from a blockage of some sort your gonna find water droplets building up on and around the dryer,you need to clean out the dryer and this should be done every year so you don't have a fire also more so if it's gas with an open flame in the dryer,if you have a long vent line run from the wall to the outside use a leaf blower to clean out the line,first run the dryer and check outside to see if the flapper is blowing fully open,if there is a cage on the hood,throw it away,all it does is collect lint,if you want to keep it go out and clean it every month,if it's low to the ground this is used so no animals can crawl into the line,now unplug the dryer,take off the front panel and vac out the inside,then clean the duct that the lint filter slides into,ge drums ride on a rear bearing and the heater is on the back wall behind the drum,if you look inside you'll see holes in the back wall of drum,if you have a shop vac put it on blow and blow out the holes in the back of drum,alot of lint collects in there,hope this helps,you definetly have a block somewhere and the is is being restricted
Dec 17, 2009 | GE Dryers
Clothes dryer is squealing when turned on. suspect drum bearing. looking for a diagram for dismantling can i take the top off without removing the back panel( GE 5 cycle dryer)
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to Appliancepartspros.com it item 316 they also have a diaphram.
Oct 10, 2009 | GE Dryers
Dryers drum is not spining
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
Nov 25, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Dryer model#DWSR483EA1WW
you need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Jun 08, 2008 | Dryers
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
