Question about Pioneer CDJ-1000 CD Player
No power to my cdj 200. I've checked the fuse
No power to my cdj 200. I've checked the fuse and the circuit board switches. Any ideas??
  • 2 more comments
  • jquintana85 Feb 25, 2009
    I just noticed that it actually does turn on. The screen is really dim, I thought it wasn't on. You can't see any text just a few red lines going horizontally.
    how many total fuses. What contacts do I use to test the continuity?
    there is power to the socket.
    Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your posts, a couple of possibilities:
  • it is a display problem. To confirm play/use the unit. If everything else works, then display problem is confirmed. This could be a backlight failure or supply to the display failure. If it is dim, then insufficient supply and could simply be a dropping resistor, voltage regulator or capacitor leak;
  • if other functions will not work, then it would be a power supply issue. Offhand, it could be voltage regulator and/or any of the multiple B+s outputted by the PSU.
  • in some other instances, this could be a faulty/leaky capacitor or a cold solder issue.
Either way, repairs call for voltage checks and opening the unit. This requires familiarity with electronic components & circuitry, use of a DVM and a soldering iron. Access to a Service Manual or at the very least a schematic diagram would be to your added advantage. Should you be uncomfortable with a DIY (do-it-yourself), then perhaps your best bet would be an authorized service center or a qualified professional.
Good luck and thank you for using FixYa.
Posted on Feb 25, 2009
    Brigadier General:
  • 5,158 Answers
Have you tested the socket ?... just grab a table lamp and plug it in and see if there is power to it
Posted on Feb 24, 2009
  • 15,935 Answers
There is an internal fuse. It may look good, but test it for continuity out of the unit.
    Genius:
  • 1,269 Answers
Try to check the continuity of the power cable using ohm meter, maybe that's the problem. Also check if there's power output from the mains.
  • 1,800 Answers
Check outlet or power supply
Hello, I have a small problem with my Pioneer CDJ-200 and i hope you will help me with an advice. It's about the ''play'' button which is working but something is wrong with its spring when you push,...
Hello
You are dicussing about the microswitch that fitted on your CD payers' control printed circuit board; I understands. If so, it can be replaced. Microswitches are of many types with different sizes and pin confugurations. You just desolder it out from the circuit board, and go for a same type, both in size and confuguration. Keep a keen look at its height, whcih cannot be exceeded of the present switch fitted in your CD player. Insist on exact size, and go with that sample you have resoldered it out.
Microswitches are available easly, on all electronic sparepart shops, and are cheap in price also. OK
Dec 01, 2010 | Pioneer CDJ-200 CD Player
I have a CDJ 200 cd player the power when turned on there is no display YASH
Hi Yash,
pls make sure and check the fuse of your CDJ. Also check the power output that is 240v or 110v.
thx,
djajay
May 25, 2010 | Pioneer CDJ-200 CD Player
No audio on cdj 200 after a power failure
check the fuses to see if they are any good
Feb 17, 2010 | Pioneer CDJ-200 CD Player
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
CDJ 200 without electricity fuse blow off?
no you cannot do that , the device works on 120v( 117v around me) , but it cannot be changed like that , you would need a trans former that breaks down the voltage to 120v
changing the fuse will not change the circuitry in the device
Nov 30, 2008 | Pioneer CDJ-200 CD Player
Pioneer cdj 200
the fuse was blown inside!!
Aug 11, 2008 | Pioneer CDJ-200 CD Player
Fuse Replacement
Hi diamonddan11
I have given you direct instructions as to where the fuse is on your original post. The fuse is located inside the unit on the same printed circuit board as the mains power socket, right beside the main power switch.
regards
robotek
Jun 21, 2008 | Audio Players & Recorders
Power
You need to check internally, Transformer/rectifier could be bad, disconnected wire, blown internal fuse. Can you rub the needle with your finger and get sound? Is it just the table not turning or is the needle not getting "power" either?
Dec 04, 2007 | Pioneer CDJ-800 Turntable
Cdj 200 will not turn on
It actuall might be the fuse or there is a little short circut switch on one of the boards. That switch could have gotten moved.
Nov 20, 2007 | Pioneer CDJ-200 CD Player
Pioneer CDJ-1000 CD Player Logo
293 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
