Question about Pool & Spa
Jacuzzi magnum pool pump impeller broke
How do I get the Jacuzzi magnum pool pump apart so I can get to the impeller? The pump runs but no water is pumped to the filter. I ran water through the intake inline (skimmer to pump) and there was no clog. I figure the impeller must be busted.
I want to know how to get to the impeller so I can replace it The pump is not attached with any screws to the filter area.
  • 125 Answers
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Posted on Feb 24, 2009
The actual strainer/pump housing on the Magnums' are usually attached to the motor by a large nut. Under that nut and it should pop right off, then you can proceed to take off the impeller as PartsCenter suggested. Try not to break it off though...Jacuzzi went out of business in 2006 and parts are sparse.
Posted on Sep 05, 2009
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
How to change the seals on a jacuzzi magnun force 1 hp pool pump
If you haven't already figured out how to change the seals on your Jacuzzi Magnum Force pump, I can help by supplying a diagram.
Here is the parts explosion for that pump.
Start by removing the case/basket assembly, then the diffuser to get to the impeller. Loosen the impeller to get to the seal plate.
When going to the trouble of changing the shaft seals one should change all the hosing seals at the same time because its a lot of work.
Jul 02, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
How to dismantle a jacuzzi magnum pool filter pump 1228
When you go to loosten the lock ring you will need to find the lock tab that will keep it from comming off. This tab I think will pull out but it may push in and this will free the ring to turn. Once this is off if the motor runs turn it on for a second and let it push the front and back half apart. If it won't run you can use a flush bag to pressure it off. In worst case you can pry the halvs apart with a big screwdriver. If you do this be careful not to hurt the case of the pump it is just plastic.
When the pump is opener you remove the difusser and look inside the impeller. If you have a screw in the center of the impeller it will be a left hand thread so to remove you will turn it clockwise. Now just unscrew the impeller turning it counter clockwise and take the rear plate off the motor by removing the four bolts on the back. Good luck.
Sep 03, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Jets wont work i can hear the motor runing but like no water sirculating
I think you have spun the center out of the impeller. Get a replacement impeller at your pull supply place.
Jul 14, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum 1000 - overheating & looking for manual
Loosen the motor and impeller from the pump by backing off the large plastic nut and take that whole section to an electric motor repair shop for inspection. If the motor is salvagable, they can quote the repair or replacement.
Jul 05, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a jacuzzi magnum 1500 pool pump which leaks. I changed the O-ring and it still leaks. If I have to change the seal on it, how do I change it. I tried undoing everything on this pump. Thanks!
You need a 201 seal for the pump. Most electric motor shops that work on pumps and of course pool store carry these. If you are unfamiliar with how to change the seal, the charges to have it done are usually low. We charge $15 - $30 depending on how much of the pump is brought in and therefore remains to be taken apart to replace the seal. The seal is about a $5 item.
If trying yourself, you will need to completely disassemble the pump, lock the motor shaft at the rear of the unit, spin off the impeller, and replace both halfs of the seal.
Jun 07, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My pump is running however it's pressure is less than 10 psi and the heater on the pool will not run.
With the Jacuzzi Magnum pool pumps, low pressure is going to likely be cause by one of the issues below. Try these troubleshooting tips.
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Jun 06, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Getting to impellre
the impeller is what is holding it in on the end of motor is the impellel the impeller is in a houseing right off motor that is held togethere by screws you should disconect power then power for motor then remove water in/outtake there may be some kind of strap holding it down
Feb 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pump won't shut off
You need a new impeller kit. Does any one know where to find one?
Jan 21, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Pool & Spa Logo
1,255 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
