Question about KitchenAid Architect S Series II KUCS03FTSS Fully Integrated Trash Compacto
Trash compactor will not solid pack
When switched to solid pack mode, ram will engage trash and then return to the top of compactor.
  • Anonymous Apr 13, 2009
    Yep, I have teh same problem. When solid pack is on it runs just like a normal cycle and the ram returns to the top. No solid pack :(
2 Suggested Answers
  • 1751 Answers
SOURCE: I have a KitchenAid Trash Compactor Model
Hi
you better replace the unit
is not relibly try fixxing it
Posted on Nov 26, 2010
ftw1952
  • 10319 Answers
Just last month I began having the exact same problem as that listed above with my Kitchen Aid trash compactor (which I believe is made by the same company as the one listed above). I searched the internet for a solution and couldn't find anything on it other than this post. I too checked out the limit directional switch and even went as far as opening it up and looking inside of it to see if any of the contacts were fused... but they weren't and it was fine. Then, I noticed that the "solid pack" feature wasn't working properly either. The smashing foot should stay down when this is on and that wasn't happening...this turned my attention to the "on" button that gets pressed when you push up on the start peddle. Turned out THAT was the problem. That button was stuck (or possibly fused inside) in the on position. I was able to fix it by simply depressing the button all the way in and letting it snap back up a few times. This completely solved the problem. If this happens again I will simply replace that part but so far, after about 20 compactor cycles, there hasn't been any problems.
What causes ice in ice container to freeze into a solid block?
The water control valve has trash in it or is otherwise malfunctioning and isn't shutting off water completely when filling the ice maker. Water then leaks over into ice bucket and freezes solid.
Sep 01, 2014 | Frigidaire Refrigerators
I have a kitchenaide compactor. The ram is down and the door is open completely.
Sounds to me like you may need to turn off the breaker and hope it resets to the open position. or if you can see the plug you can unplug it.
Aug 24, 2014 | KitchenAid Architect S Series II...
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
Compactor will not operate. The foot lift switch will not work to turn compactor on. I don't know if the compactor is in the full up position or down because when we got home...our 21 year old daughter...
You probably need to replace the actuator switch, part #9871976. This is a piece of metal that is attached to the foot pedal and pushes in the start button when foot pedal is lifted. Mine has broken twice.
Nov 15, 2010 | KitchenAid Architect S Series II...
I have a compactor KUCS03FTPA. Cabinet maker is wondering how to install wood panel on face of compactor..can you please help? The manual does not have detailed instructions
the appliance comes with a stock face on it. You should be able to remove the face by sliding out of its track ,and sliding the new one in it's place. Sometimes certain units have a quick latch attachment. In that case you need to just figure out if you need to hit the panel up or down(like those shelf brackets that went on a wall) to get it to pop off.
Oct 22, 2010 | KitchenAid Architect S Series II...
Foot switch will not start the unit. Power is on, compactor is full
check the metal tab/levr that is connected to the foot petal.
If the scew is loose, it won't have enough pressure to push the button.
Mine came loose all the time, so I finally added lock tight.
Jan 29, 2010 | KitchenAid Architect S Series II...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
G.e. profile compactor gcg1540f0ss
the nut on the ram drive fell off for me and the chain fell off and then broke the grear drive. At 72$ each for the two ruined gears I don't know if I should try to repair it or get a new one.
ERRR
Dec 02, 2007 | GE Profile??ยข Built-In Compactor - 15" -...
KitchenAid Architect S Series II KUCS03FTSS Fully Integrated Trash Compacto Logo
187 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
