Question about Samsung HL-P5063W 50" Rear Projection HDTV
Red Stripe When I turn tv on it gets a red horizontal stripe accross top of screen and any shadows on picture has red static haze with red outline on every thing. Is this a color wheel issue? Sears had diagnosed as that but wants to charge $500 to fix. Just want to get a second oppinion.
    Novelist:
  • 159 Answers
The cost of the repair is fair. The color wheel is about 175.00 some other areas in the tv with the kind of problem you are relating can cost the board just above 200.00 until 350.00 then only the color wheel can practically cover the cost you are about to do. Plus labor. make sure they give you the 3 months warranty.
Posted on Apr 08, 2009
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal line appeared at the top of the screen and it has grown to about 3 inches now. The picture itself is...
The lenses in the TV are more than likely misaligned due to heat from lamp. The heat can cause the lenses to move and the red shaded horizontal line appears over time because the lenses fall out of alignment.
You just need to have the lenses realigned and the red shading will go away.
Jan 07, 2010 | Sony Televison & Video
Turned on my TV today to find a 5" horizontal stripe across the middle of my screen. I can view the picture through the stripe but the picture brightness on the top 1/3 and bottom 1/3 of the screen is much...
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
Hope this helps
Nov 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
I have a red stripe across the top off my tv
This issue is because of a defect in the light engine. The only way to solve is to replace the whole light engine. They usually run anywhere from $500-$2500 depending on the model. Sony extended the warranties for the light engine on certain models that have this problem because of the defect, contact Sony to see if a certain TV had the warranty extended.
Oct 05, 2009 | Sony Televison & Video
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
2" wide Red stripe on right side of LG 42" plasma TV screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Jun 09, 2017 | LG DU-42PY10 42 in. Plasma HDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Light red translucent stripe at top of screen
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
My six month old Dynex DX-LCD32 TV has developed a problem. A bright red horizontal stripe about 2 inches thick and the width of the screen is blocking my view of the picture. It's positioned about a...
I'm sorry to say that those lines or interference are cause by a hardware failure and no adjustment can correct it.
If your TV is only 6 months old, still cover under manufacturers warranty. Call the manufacturers and ask them how to go about this repair and hopefully they will send you to an authorized service centre.
Hope this helps.
Apr 15, 2008 | Televison & Video
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
104 people viewed this question
Henry  Thomas
Henry Thomas
