Question about Lexmark X1150 All-In-One InkJet Printer
Just changed cartridges - power is on - lights on - push COPY button, NOTHING happens
  • Anonymous Feb 26, 2009
    ambot lang... wa raro....
  • 530 Answers
Hi im josh in cebu phils. Friend may i helped you? if you've installed the cartridge then nothing happens. Your printer haven't  yet charge the ink. you go to printer settings the click the ink replacement just next next then after it will detect.you wait for a while the ink is charging it will take some time to complete. you wait it until it will told you to so.don't exit. then after go to ink status icon.check if it is confirm through the level shown.then thats the time to exit. then try to print. good luck
Posted on Feb 24, 2009
The cartridge error message seems stuck in memory
Please turn off the printer and disconnect the power chord and the usb cable, open the scanner door/backdoor, etc.. Remove the cartridges and clean cartridges contact points. Leave it for few minutes without any connection. Power on only with the power chord connected and without installing the cartridges and again leave it for few more minutes, switch it off. Reinstall and reconnect all the cables. Restart your system and boot up both the Pc and the printer simultaneously while you keep pressing the power button of the printer. Note that you have to use only the power button to switch the printer off or on. Good luck. Thank you for using FixYa.
Jun 05, 2010 | HP PSC 1210 All-In-One InkJet Printer
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Ink cartridge unit will not move to replace
Printer has pads for excess ink, once pads are full this happens.
Pads will need to be replaced
Jun 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Problems replacing ink cartridges in epson 1000 ics
Turn off printer, unplug it from power supply.
Replug and turn it back on
Tilt scanner so that you can see the printhead, press menu and select change cartridge, press copy button.
Feb 24, 2008 | Epson 1000 ICS All-In-One InkJet Printer
HP PhotoSmart C4180 All-in-One... Problem:
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
Epson rx500
Ensure that all the plugs are connected correctly
Jan 27, 2008 | Epson Stylus RX500 All-In-One InkJet...
Machine sleeping even when re-powered on
Hi try changing the fuse in the plug first. Once you have done this then power in and open the cartridge cover and press the cartridge button. If the cartridge moves then the LCD has blown and will need replacing if nothing happens then unfortunately the power supply board has blown then replacing the whole machine is the cheapest option.
Thanks J
Nov 22, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
