Question about Whirlpool Washing Machines
My Washer WTW6600SWP 2 1/2 years old. keeps stopping on 13 minutes. Nearly EVERY Load, then I will do two - three loads without issues. this can be jeans shirts undies towels sheets does not matter it can do it small load or large load or medium load. Also when I cleaned it last month it took over 7 hours and never completed the cycle!!!!
  • 1 more comment
  • arla366 Feb 24, 2009
    ok the problem is the timer selector switch how do i go about getting one and getting it fixed?
    Check the timer swith clean all the contacts on the control board
    let me know
    OK MICROMASTER THANKS,
    only problem is no one is mechanically inclined in this house, we are the machine owners??
    A&E appliance services have been no shows twice on a service call. Frustrated as this has been
    going on over 7 weeks and it takes more than a day and a lot of creative attempts to finsih the load but as I say it tales all day wash is really backed up
    cycle!!!!
    I hope still have a question ut there as towhat to do hire a pro or what
    Brigadier General:
  • 3,614 Answers
Check the timer switch., clean all contacts on the control board.
let me know
Posted on Feb 24, 2009
  • micromaster
    micromaster Feb 24, 2009
    better to get a service engineer to check thoroughly the unit at this this time, circuit board may function incorrectly and need an immediate response
    Brigadier General:
  • 8,619 Answers
Hi!
The problem is with the Timer selector switch which needs to be replaced.
  • 4 more comments
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    Please tell the Brand & model no. so that more information can be provided.
    Please revert for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Please see this link on how to dis-assemble the Machine--
    Whirlpool WTW 6600
  • Rylee Smith
    You can buy the timer switch from---
    Timer switch Whirlpool
  • Rylee Smith
    Please rate the solution if you have found this helpful.
    Thanks
    Rylee
  • Rylee Smith
    If you can then order the timer switch from the link---
    Washer timer
    See this link for timer replacement-
    Timer replacement
    Or you can get it replaced by a repair person or from sears---
    Sears
    1-800-4-MY-HOME
    (1-800-469-4663)
    Thanks
    Rylee
  • Rylee Smith
    The timer for your WTW6600SW2 is available at---
    WTW6600SW2
Samsung washer keeps rinsing and draining and back through same cycle
Hi.
This sounds like the load is out of balance, and the machine is refilling to re-distribute the load. It senses the load during the beginning of the spin cycle.
It could be that the load is too small or that the garments have different density and water (weight) retention.
It could also be that the springs on the rods which support the bowl have sagged and have allowed the bowl to hit the out of balance switch. It could even be that the machine is rocking because the feet are not adjusted evenly..
I hope this helps you work out the problem.
Good luck.
Nomess
Feb 19, 2015 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
It stops about 13 minutes from the end of the cycle, right before it spins. It displays NF.
""It stops about 13 minutes from the end of the cycle, right before it spins. ""
NF is no fill for the FAV6800A and FAV9800A are you still having the issue.
To me it sounds like you have two issues
""It stops about 13 minutes from the end of the cycle, right before it spins. "" with no additional info this could be a issue with the Clutch Pulley. Did you take any error codes like DC or UC?
Are you going to DIY the fix or call in a repair service?
Jan 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Our Kenmnore Oasis Model 110.2703 washer gets out of balance with all size loads and stops due to excessive vibration. The washer was checked with a level as required by the manual and is level. The...
Raise the lid by depressing the clips that are about 2" in from each side. See the white plastic "balls" that lie in sockets on top of the suspension rods? Lift them up and clean the socket and ball on each corner, apply new grease and you should be in good shape. Two people make this a whole lot easier.
Jan 13, 2011 | Kenmore Oasis 27042 Top Load Washer
I have a Kenmore Elite HE 4t front load washing machine. Code F ud is currently flashing and the door won't open. I've tried canceling but it just beeps and keeps flashing this code.
Remove the bottom panel. The tech sheet is located beside the white box to the left.088d3fc.jpg It gives diagnostic directions and failure codes. Suggest you clean the dispenser area up04f0b28.jpg and use the correct amount of HE detergent.
Seems to me like that is a suds detect:All front load washers require "HE" detergent (a low suds type detergent).
There are three commonly sold concentrations of HE type detergent.
HE : (2) Tablespoons Per Wash Load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated) : (1) Teaspoon
Most consumers follow the directions on the bottle or box of detergent--which is normally the correct thing to do. However, the amount recommended in nearly all brands of HE detergent are excessive & incorrect.
Additionally---using the correct amount of HE detergent will end issues with:
1) Musty Odors
2) 'LE" Errors (that can cleared by unplugging the washer)
3) L-O-N-G cycle times (longer than time displayed).
A 51 minute cycle can take 120 minutes to end.
4) Insuffificent Cleaning Results
5) Small water leaks behind the washer at the air vent.
(Suds oozes out during the spin cycle)
May 19, 2010 | Kenmore Washing Machines
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Constant resetting
it may have a blocked up pump so keeps trying to spin out water.But your under warrenty.call GE they will send some one out to fix that for you
Dec 31, 2008 | GE WCVH6260F Front Load Washer
My GE Profile Washing Machine Keeps Stopping
Repair requires replacement of the transmission / break assembly. Unless you are really attached to this machine, it's time for a new machine. Average life of a washer is about 11 years doing 8 loads per week. Look into the front load machines, which use about 1/4 the water and spin about twice as fast, and are gentle on fabrics while cleaning very well. Please don't bother rating this, as non FixYa ratings drop my rating, and I'm sure you don't want to shoot the messenger.
Oct 14, 2008 | GE WBSE2090A Top Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal De
