Question about Husqvarna Garden
Husqvarna Riding Mower won't turn over
Model YTH2042
When I go to start the tractor I turn the key and it cranks up but it will not start up. I just put a new battery in it
It could be a combination of things... it could be a loose earth lead from your ignitor pack or your timing could be out, check your key way that will be in the centre part of the magneto.. too see if its ok will need to remove the magneto to see the key way if its brocken it will not fire up and sometimes will back frie through carb if its bad enough, also check your gap between the ignitor pack and magneto should be around the .20 too .25mm by feeler guage...
Jay QLD AUS
Posted on Feb 24, 2009
Husqvarna mower
you have something hooked up wrong,they should not be near the spindles,is it on backwards?, http www searspartsdirect com model part yth2042 3199 1509200 p0804135...
Jul 07, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Mower will not start after changing the battery out and checking all connectioncs
U could try to use some starting fluid spray into carb and have someone crank it right away But first do you have fresh gas in the tractor if not I would drain and fill tank with fresh gas. Also I always change my spark plugs at the beginning of the season,
Apr 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Apr 28, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My 42" Husqvarna (model #917.279240
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
May 15, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hot battery,will not turn engine every time,keep bumping key and will start turning engine seems like trying to start with too much compresion
If your unit has OHV engine you need to check the intake and exhaust valve gap. Call your local repair shop to get numbers and check this website out. Go to smalleng.com they have a video for just what you are looking for. Good Luck...
Apr 03, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Garden Logo
959 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
