Question about Motorola Mobility RAZR V3i Cellular Phone
Hi, phone turns on only for 1 second and turns off
  • 530 Answers
Hi im josh in cebu phils. friend may i help you? Friend the problem is in your battery try to check if it was fully charged.2nd the connection the battery terminal is in proper contact. good luck
Posted on Feb 24, 2009
Hi, i have 2013 bmw x3. I had it paired to my old iPhone, just upgraded to the new iPhone 7 plus and cannot connect the Bluetooth on the car to the phone - any ideas?
1. Press and hold the button with the "speaking face"on the steering wheel, then after three seconds, turn the ignition key to position 1 and release the button after approximately 3 seconds. "BLUETOOTH PAIRING" appears on the display or monitor.
2. Press the button again for approximately 10 seconds until you hear a triple acoustic signal.
PAIRED DEVICES DELETED appears on the display.
3. To finish the deleting process, turn the ignition key to position 0.
All the phones that were originally paired are now deleted.
Try pairing the new phone again.
Feb 03, 2017 | Cell Phones
Hi my 6300 wont turn on again
Hello:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Feb 06, 2013 | Nokia 6300 Cellular Phone
I bought this phone second hand and its locked as soon as you turn it on is there a master unlock
Try the master reset codes, That should unlock and reset the phone completely and forever:
Input these keys in this order:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
This should work. If not, let us know!
May 09, 2011 | Samsung SGH-A877 Impression Cell Phone
When i try to turn on my slvr the keypad will light up for a few seconds then turn off...I tried taking out the battery and replacing it wit a brand new 1 without any luck. I also tried just pluging it...
Hi, problem can be solved.
What causes the keypad will light up for a few seconds then turns off, is because the keypad has a separate function from the phone. (it has a removable keypad). And the keypad inside the cell phone is getting Bad and it needs to be replaced.
You can know how to disassemble the cell phone through the link below:
http://www.formymobile.co.uk/l7disassembly.php
When you replace the keypad,phone will be ok again.
Thanks for using fixya...
Feb 14, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Screen turns off after 10 seconds on i9 phone how do i change this.
Hi lainybrook. Does your LCD screen go black, turn off, or go into a sleep mode state to quickly, then try this ...
Depending on the phone firmware, you may be able to change the time for this function by following the listed steps:
1) Open "Settings"
2) Open "Phone setup"
3) Go down and open there "Misc. settings"
4) Open "LCD backlight"
6) There you can change the Brightness of your screen from 1 to 5 and the Time (sec) from 1 to 60.
See how this goes.
Dione
Feb 17, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Nokia 5220 turning off and on
if your phone restarts by iteslf this means that there is probplem with your phone memory or there is problem with the phone software(firmware).
1. Please do a reset of the phone using this code *#7780# and *#7370#
2. Please take your phone to Nokia service center to update the phone software.
hope this should resolve your issue.
Mar 26, 2009 | Nokia 5220 XpressMusic Cellular Phone
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Unlockig code
and follow the steps
Howto use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345
Aug 03, 2008 | Nokia N95 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
