Monitor keeps shutting down...
After sitting idly, the monitor naturally shuts down. Usually the movement of the mouse is enough to power it back up...lately it's not. Sometimes a "no signal" message flashes for a second but it doesn't come on. About a half hour or so later, the monitor comes back up by itself.Also, sometimes when I'm on the computer, the monitor just goes black. It'll flicker a bit like there's a loose connection and come back eventually not losing the page I was on. I've checked the connections and they are fine. HELP!Thanks, Mark
  • Anonymous Feb 24, 2009
    I don't believe I have a video card???
  • 530 Answers
Hi im josh in cebu phils. mark the problem centeres in your video card try to check if it is in the proper temperature (not heat or  hot). check if it is seated firmly in the slot.
Posted on Feb 24, 2009
My studio monitor keeps shutting off!
It's shutting down automatically due to heat peaking. You need to turn off until you are ready to use it.
Apr 11, 2012 | Adam Audio Audio A8X Powered Monitor
HI HAVE A NEW AOC COMPUTER MONITOR FROM AOC. IT SHUTS DOWN EVERY TIME I LEAVE IT AND I WOULD LIKE FOR IT TO REMAIN ON ALL DAY LONG AND I WILL SHUT IT DOWN AT NIGHT MANUALLY; HOW CAN I DO THIS. ...
go in to monitor in the control panel and set the sleep mode time mode
probably better if you go into bios setting and click on computer start from any key movement
that way the monitor and computer go into sleep mode and that saves money on power and you only have to move the mouse or press a key and 10 seconds later the screen is awake and the computer is operational
I am typing this looking at an aoc monitor attached to a pc ;
Sep 13, 2017 | AOC 931SWL 19 inch Monitor
Inspiron 530 desktop--- computer boots up, runs just fine for a while, then monitor displays gabled multi-colored patterns, then evetually shuts down.
What is shutting down, the monitor or the computer. Check the power light on each for proper diagnosis. You either have a bad monitor, a bad video display card or a bad PC, specifically a power supply or motherboard. This is a classic symptom of something getting too hot and shutting down. One way to test the monitor is to plug it into something else for an a period of time and test. If you're PC is shutting off, try unplugging unnecessary peripherals, i.e. CD/DVD drives, floppy drives, external USB peripherals, etc. Start with just the video adapter, keyboard, mouse and monitor. Let us know what is shutting off, for further diagnosis.
Aug 13, 2011 | Dell Inspiron 530 Desktop Computer
My monitor goes blank while watching a movie on netflex about every 8 min very annoying . I jiggle the mouse and the picture comes back . sound ok . Help
Your computer is just going to sleep from what it sounds like.
Just get into the monitor/power saving/screen saver settings and make it so the monitor has a longer relay to shut down when there is no mouse/keyboard movement.
Jul 05, 2011 | Dell Inspiron 560 Desktop Computer (Intel...
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
How do I get a monitor out of hibernation mode? It is not responding and did not reset when I rebooted.
Try using the power button, which usually takes the computer out of hibernation. Also, the mouse and keyboard can sometimes wake the computer from hibernation as well.
If the computer is still stuck in a hibernated state, hold the power button in for about 5 seconds so the computer fully shuts down and power it back on.
Good Luck!
Aug 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Fujitsu-Siemens Monitor problem
usually shut down when idle(idle means no key or mouse activity).........left click mouse in any space on desktop,select properties,in properties window select screensaver and lower in the screen youll see power settings..select it...in power schemes change time best suited or select never.
Feb 24, 2008 | Computers & Internet
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
