Question about HP OmniBook Vt6200 Notebook
My hp omnibook vt6200 have screen failure... When I turn them on I have black screen and I can't see nothing....but when I plug other screen than he works perfect.... Thank you very much Regard...
  • HP Master
  • 4,806 Answers
Hi there.
while you have the external monitor plugged in and you have the display on that monitor, hold down Fn and look for a F key which has a TV/monitor icon on it and hit that key (you may have to hit this once or twice) this is whats called the keyboard toggle switch, if your laptop monitor comes on then the problem is sorted and you can disconnect the external monitor.
Post back with the results please
Good luck and thanks for using Fixya!!!
Posted on Feb 24, 2009
Hp omnibook xe4100 repeated beeps then black screen comes out. to start my laptop i press esc button before the beeps comes then esc again till i see mya windows
Try reseating the memory cards in the notebook to make sure they have a good connection.
if they lose connection you will get a black screen.
Jun 26, 2010 | HP Pavilion dv6000z Notebook
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
Keyboard problems
Is the keyboard flexible cable the same pin as the original keyboard? If yes and you are sure the new keyboard is okay, then you can change the language to the preferred language e.g US English, change its position to the first and make it referred. Its should work. You can also check online if there is any keyboard or input driver which when installed can be of help.
Apr 12, 2017 | HP OmniBook Vt6200 Notebook
Dark screen, no backlight
I am sure that your BACKLIGHT is dead...Have someone or a tech take a look at it. The problem can be the backlight or the inverter itself... But most likely it's the backlight that goes out. You might be better of getting the LCD screen replace... Unless you find the backlight for that laptop model...
But first, play around with the BRIGHTNESS settings, make sure it's not on VERY LOW...
Sep 26, 2009 | HP OmniBook Vt6200 Notebook
My hp pavilion tx1000series won't boot even at bios
EXTREMELY common failure in the TX1000 line. Problem is the mainboard, part# 441097-001. From HP it should only be about $200 on exchange. DO NOT get this part anywhere else, as the OTHER common failure for this model is the wifi goes out.
I do about 10 of these TX's per day, no im not kidding, and i promise you HP has the most stable parts source around for this.
-Sy
Jan 18, 2009 | Eizo I-Station Networking Hub
English language support on laptop with German Keyboard
The easiest solution will be to locate a replacement laptop keyboard for that model. they arent hard to replace and usually cost between $40 and $80. I would web search HP Spare parts Third party is usually cheaper. Keyboards are pretty common replacements on laptops due to wear an tear. Most are replaced using a small phillips screwdriver. Its likley you can find removal instructions on the web as well (if they dont come packaged with the keyboard.
Dec 24, 2008 | HP OmniBook Vt6200 Notebook
Screen problem....PLEASE HELP ME!!!
how to fix screen problem on my laptop
Sep 10, 2008 | HP OmniBook XE3 Notebook
HP omnibook 6000
http://www.retrevo.com/search?q=omnibook+6000&rt=pd
The above directs you to the manual of your notebook.Please do rate if this solves the problem.Thank you.
Jun 19, 2008 | HP OmniBook 6000 Notebook
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
HP OmniBook Vt6200 Notebook Logo
173 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
