Question about JVC Video Cameras
DOOR WONT OPEN
I HAVE A TAPE STUCK IN MY JVC CAMCORDER THE DOOR WONT OPEN JVC GR-AXM70U 36X DIGITAL QUICK RESPONSE AF
5 Suggested Answers
  • 32 Answers
SOURCE: i want to capture movie from dv tape to compaq presario notebook
You are mentioning that you are trying to transfer video though USB port, that is not possible, you have to connect the to the pc through the DV port from the camera to the Firewire port of the PC, if your PC doesnt have a Fire wire port, install a IEEE1394 firewire card in one of your PCI slots.
Posted on Dec 01, 2007
  • 169 Answers
SOURCE: JVC Cameras - GR-D70AA MiniDV Digital Camcorder - iris replacement
the ccd image sensor of your camera is the problem...i know it is free for replacing that sensor..that trouble is also in sony,canon,samsung and the other cameras brand cause the manufacturer of their sensor is only one company that why they recall it from the batch of 2002 to 2004..log on to the jvc costumer care to see all the detail...
Posted on Dec 16, 2007
kala
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
rroath49
  • 35 Answers
SOURCE: JVC Gr-DVL300 Won't playback
The heads are probably dirty. First you can try to let a tape run through from start to end and see if it cleans the head. then try running in reverse play scan. Next try a head cleaner tape if you have not yet. If these things do not get your picture back you should take it to a repair shop, I do not recomend taking camcorders apart for cleaning at home. Full size VCR's are ok to clean your self with instructions but not camcorders because they are vary easy to damage worse without experiance and proper tools.
Posted on Jul 31, 2008
welcomejee
  • 10594 Answers
SOURCE: i have a jvc gr-d347u camcorder. i haven't
This kind of symptom appears in camcorder when its video head got dirty/ clogged, put video head cleaning tape in camcorder and clean head as per instructions provided with cleaning tape.
You can buy video head cleaning tape from Radio Shake or any store.
Thanks.
Posted on Dec 14, 2009
JVC Camcorder Tape door stuck
michanical dis arrange inside the tape socket
Mar 20, 2010 | Video Cameras
I have a jvc gr-dvl815 and the housing for the tape seems to be stuck and won't open. Is there a manual way to open it?
In this model, it's hard to access the mode motor to drive it manually. Open cassette door, see the motor on the left side try to access and drive it by 3V battery to its contact. Otherwise; send it to service center. Good luck
Feb 26, 2010 | JVC GR-DVL815 Mini DV Digital Camcorder
CAMCORDER WILL NOT PUSH IN A TAPE, STUCK HERE
Posted by delmas263 on Jan 02, 2009 I have the same problem, The camcorder will not take in the tape, stuck the tape holder will not go back in, notify me when you have a solution. Thanks
Dec 19, 2008 | JVC GR-D244US Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
Camcorder broken -How do I remove tape?
I saw a little wheel in there, so I took a pointy scissor and turned it. Closed and re-opened the tape door, and it popped out!
Sep 10, 2008 | JVC GR-D350 Mini DV Digital Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Jvc digital video camera gr-d244u mini dv
My jvc gr d244u digitial camcorder it torn up. when i go to eject the tape and it pops out it want retract it back in. what can i do to fix this problem.
Jan 04, 2008 | JVC GR-D244 DV Digital Camcorder
Tape door will not move; stuck in open position
there should be a 800 number to call 1-800-555-1212 as the operator for a the number support JVC. you can go to there site www.jvc.com (i think)there you can find a local support repair shop. you can a chance open look inside real hard to see if something pop out of place in it. i know it stick a lot, me and my aunt have both JVC Camcorders my is a older model her's is a newer one. i would seek out a support center who work on them, seek out JVC and see if there a local repair center in your area
Jun 27, 2007 | JVC GR-D270US Mini DV Digital Camcorder
Video Cameras Logo
142 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
