Question about Whirlpool LER5636P Electric Dryer
WHIRLPOOL DRYER WILL NOT START
MY GE DRYER DID NOT TURN ON, SO I CHANGED THE FUSES IN THE FUSE BOX, STILL DID NOT TURN ON. SO I GOT ANOTHER DRYER, IT WORKED FOR ABOUT 3 LOADS AND LATER THAT NIGHT IT DIDN'T WORK (COME ON) AGAIN? PLEASE HELP, IS THERE A FUSE INSIDE THE DRYER OR IS IT A THERMAL FUSE ON THE INSIDE?
  • ceaze09 Feb 24, 2009
    so it would be the wall outlet after some 5 years of the GE dryer working?
  • Whirlpool Master
  • 3,361 Answers
You have a bad terminal in the wall outlet.
It is not the dryer.
Posted on Feb 24, 2009
GE Microwave model # JVM1740DM1WW will not start. I have turned fuse box off, and turned on again and it still will not turn on. Also, before it went out totally, I was having trouble with the microwave...
Check for a internal bad fuse or dio inside cover....Caution...If you don\'t know what your doing get someone certified to do it. I don\'t want you hurt!
http://m.wikihow.com/Change-the-Fuse-in-a-GE-Microwave
Aug 22, 2013 | Computers & Internet
Dryer won't turn on
Is your dryer electric or gas. If electric, check your fuse box first thing. If it is an older model and your home has an older fuse box, and the boxes uses the big bullet type fuses for the 220 line, one or both fuses could be bad. If so, go buy two new fuses and give it a t;ry.
Aug 09, 2013 | GE DCVH515EF Electric Dryer
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Takes 2-3 hrs to dry a load. Put new dryer hose on. Vent not clogged. Lint filter cleaned each load.
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Nov 24, 2009 | GE Profile Harmony DPGT750EC Electric...
MY GE GAS DRYER WILL NOT HEAT UP
check an pop the lil plastic cover on the front of the dryer an then turn the dryer on an see if the igniter glows after 30 secnds if it glows........** you probably have bad coils****if it doesnt then check the thermal fuse for continuity if is not checking ok replace it , that is one of the most common causes,
steps
1 check igniter for glowing
2 check thermal fuse for continuity test
3 if they both check ok an still no heat change the coils
good luck!
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
