Question about Dual Electronics CECT P168 Cellular Phone
HOW DO I CHANGE THE ALARM FROM AM TO PM? - Dual Electronics CECT P168 Cellular Phone
Use military time.
Posted on Feb 24, 2009
On my Eddie Bauer alarm clock, how do I change the time to pm or am?
When you are holding the set button, advance the time until you see the indicator that you are on PM. Keep going until the PM indicator is gone for AM.
May 26, 2015 | Audio Players & Recorders
How do I get my clock radio to change to the PM indicator?
you need to set your time to the correct hour... am for am pm for pm. this mean you may need to cycle past the current hour you Think it is and go to the next example you want 3 pm and it is showing 1AM,,, you go past 3 AM all the way to the next 3 which will be 3 pm.
Oct 05, 2014 | GPX CLOCK RADIO WITH DUAL ALARM
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
Reset change oil filter alarm after filter changed
I thought this is something that I.R. had to do but it's been a while.
Dec 18, 2013 | Ingersoll Rand Type 30 Electric Driven Two...
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
Instructions for setting alarm and time on armitron 45/7012blk
To change from Military time to AM/PM just hit the reset button in the top left corner on the 45/7012. You will see a little am or pm pop up.
Feb 06, 2013 | Watches
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
How do i change the alarm time from pm to am? its not in the manuel.
http://www.lg.com/us/mobile-phones/LG-GT365-Aqua-Blue.jsp
Above is a link to your phones manual in case you ever need it if you lose the one that you have.
Time: Select the desired set time mode
using the navigation key. Input your desired
alarm time by specifying the hour and
minutes. If the time is in the 12 hour format,
you have to select either 'am' or 'pm' using
the Center key.(its just your select key)
(Repeat: Select the desired repeat mode
using the navigation key.)
Alarm Type: Allows you to choose an
Alarm type for your selected alarm.
Options are: Follow Profile/ Always Sound/
Always Vibrate.
Alarm Tone: Select the alarm sound to use
for the alarm using the Center key
This is actually found on page 65 of your manual.
I hope this helps you out. just select the format, am, pm or 24 hours like you would the time you want to change the hour or mins, .
I hope this helps you. please let me know
May 14, 2011 | LG Neon GT365 Cell Phone
Motorola Moto Q Phone Help on the Alarm
Go to phone menu
then press time & date settings
press set format
then change its format in 12 HOURS or am/pm
then save it will be change
Jun 06, 2010 | Motorola Mobility Moto Q
Time and alarm same meridiem
this is a glitch in his product.
Jan 09, 2008 | RCA RS2046 Shelf System
Dual Electronics CECT P168 Cellular Phone Logo
76 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Michael Terence...
Michael Terence...
venugopal durairajan
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
