Question about Maytag MSD2756G Side by Side Refrigerator
Where is the drain on my Maytag side by side freezer and how do I get to it?
    An expert who has answered 500 questions.
  • 531 Answers
Back wall in the freezer once you move back wall drain at the bottom
Posted on Apr 06, 2009
My maytag side by side has water froze on bottom of freezer what can I do
There is a good chance the freezer drain is plugged up. You will have to remove the back panel and pour hot water in the dain area to thaw the ice and then flush the drain.
Aug 31, 2014 | Maytag MSD2454G Side by Side Refrigerator
Maytag + mzd2752grw side by side on the freezer side ice builds up on the bottom
Your defrost drain is frozen. If you can empty the freezer you can thaw the drain with a hair dryer. You will have to turn the box off. should only take half hour. hope this helps
Aug 21, 2011 | Maytag Refrigerators
Water leaking from front base of freezer
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
First Choice Appliance
May 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Maytag side by side freezer drain icing
This is a pretty common problem. Sometimes the defrost cycle is not long enough because the freezer setting were too low. But most times this begins slowly until the drain finally closes and then the water has no where to go but the inside of freezer or refrigerator. I have more help topics to prevent a constantly happening over and over again. But you may have a blockage down-line from the freezer. So until you can melt the ice and pour a warm solution of water and clorox in the drain and it end up in the pan below the refrigerator I will hold off on that until I hear back from you, Thanks, Sea Breeze
Jul 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
New Maytag Refrigerator drains water into a pan underneath
check for clogged drain line bottom of inside of the freezer,or you can check it at back side underneath
Mar 12, 2009 | Maytag MSD2542VE Side by Side Refrigerator
Ice building up in bottom of freezer of side by side MSD27 Maytag
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
Dec 20, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side freezer leaking water and icing in bottom
Defrost drain system is plugged and not draining out the back and into the drain collector. There is normally an air trap in this drain line under the back and behind a fiber removable panel. Check this trap and make sure it is clear of any blockage. You will then have to defrost the freezer and clear out the ice. Don't forget to replace the back fiber panel.
May 17, 2008 | Freezers
Maytag MSD2756G Side by Side Refrigerator Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
