Question about Fogel FOG-CR67PCUS Sliding Glass Door Merchandiser 67 cuft
Refrigerator keep running
Put freon in it , changes thermostat but fright does not go off the black tank underneathe it freezes and the lines too the frige is about 1 1/2 year old freon replaces 2 times tec cant find leak took frig apart sprayed the lines with soap water can.t find anything
  • Fogel Master
  • 3,361 Answers
Way too much refrigerant in this fridge.
You have a bad thermostat.
Posted on Feb 24, 2009
Model#1051 small dorm size...doesn't matter where i set thermostat..it sill freezes everything,,,suggestions?
Repace thermostat. You didn't tell us that it runs ALL the time. It does. You don't have to tell me, I know it does. The first thing the power does is go thru the thermostat and its job is to turn the power off to the pump when it gets cold enough. If it gets cold and freezes everything then everything else is working right. There is no fixing the old thermostat either. That little tube that looks like a heavy bare wire ending next to the freezer coil has a little "freon" in it that expandes and contrectes with temp. change and the change in pressure is what ativates the thermostat. Chances are the "freon" leaked out.
Note, this is not the same "freon" that is pumped around the fridge to cool things. This is sealed in the thermostat and tube only.
Jun 23, 2011 | Goldstar GR131CN Compact Refrigerator
Freezer temp is -4 and refrig is 38. Not sure if these are correct settings but water in freig bladder keeps freezing and can't get water. Warmed bladder twice to get water to come out. If freezer temp...
Sorry if you don't like this solution, it does not make it work correctly. But my water works all the time now.
We too had the water dispensor stopping due to freezing of water in the storage tank. A blow dryer and about 10 minutes later we could get it working again.
We tried different fridge temp settings , and according to a thermometer placed inside the fridge in various locations we are getting the fridge temps we want, so it is not runing too cold.
I tried insulating the storage tank and the lines, this did not work.
I removed the tank and just connected the two lines, this still did not work.
I finally just pulled the lines out of the fridge completely and connected them underneath the fridge so water runs from the valve at back straight to door. The plastic panel on bottom was a great place to store the lines. I drilled a hole to reroute the door line to this area . Line runs behind lower plastic cover on front . The water does not get cold, but it never stops flowing, this was more important to us. I did consider rerouting both lines to the top shelf and putting the storage tank back in to get colder water, but no one minds the way it works so I probably will not do this. I would have run them up the back to avoid the inside lower area of the fridge. In the long run I will avoid this brand and avoid "twin-cooling" completely. All my neighbors and friends who bought this type all had to throw them away as they were too dofficult and expensive to keep running.
Jan 15, 2011 | Samsung RS2534 Side by Side Refrigerator
Fridge stop cooling , found that the charge in the compressor was very low, recharge with 5 oz and now the copper line is freezing , i unplugged it for about 2 hours and retry same freezing issue
First check and make sure that you use the right amount of freon. Freezing line is an indication of not enough freon. Also check the manufacturer's label for the correct amount to add. Make sure you weigh the refrigerant carefully while charging. You may want to obtain the refrigerant Pressure/Temperature chart to make sure you have the correct pressure. Allow refrigerator to run for a while and check pressure versus temperature. Correct pressure as needed to stop freezing.
Dec 18, 2010 | Refrigerators
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
The freezer isnt freezing solid and the fan continues to run.. fridge side is cold
check for a defrost problem evident by frost build up on the back wall of the freezer, then change either the timer, heater or defrost thermostat. also make sure coils are clean underneath the refrigerator and that the fan underneath is running
Nov 01, 2009 | Refrigerators
I have a fridgidaire freezer that is just cooling not freezing?
some freezers will not freeze in the freezer department if you are low on freon. the motor cannot produce enough freon to keep your freezer frozen when it is to low, however, you might have the temperature up to high where it has locked up the motor and is sending out all that water underneath. i would check your pan under your refrigerator to see if it needs to be dumped and then replace it back.
Jul 13, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a Sub Zero 201 F, that ices up around the freon line.
It sounds like your fridge has had some servicing done on it and has been over charged with freon and needs to be decanterred.Kind Regards.
Jul 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
Kenmore Side by Side Refrigerator
could be, but can also be a MAJOR problem not worth fixin! thermostats usually tend to be relieable for that they either cool althe time or quit altogether, the fact that freezer cant freeze ice, sounds as if its running(thermo good) perhaps a freon leak , not enough freon, bad compressor or some other sealed system issue
Nov 10, 2008 | Kenmore Refrigerators
Roper whirlpool refrigerator
Mine is doing the same thing,started today. It is going to be the timer defrost or the cold control thermostat.Timer is $20. Thermostat is $55.Both are located on the fridge side about eye level by the light.They are underneath the plastic cover.
Mar 20, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Fogel FOG-CR67PCUS Sliding Glass Door Merchandiser 67 cuft Logo
116 people viewed this question
Top Fogel Refrigerators Experts
Randy Justice
Bill Boyd
John In Milford
John In Milford
Are you a Fogel Refrigerator Expert? Answer questions, earn points and help others
