Question about Horizon Exercise & Fitness
Horizon Model 3.2E LCD showing MILE EP 5101
We turned on the machine to do a workout one day and that is all the LCD said.
    Novelist:
  • 145 Answers
I know the issue with this failure.....this is a common crash for this console...message me for further details....this is repairable ;o)
jatinahATrocketmailDOTcom
Posted on Nov 15, 2016
    Problem Solver:
  • 14 Answers
THis is a reboot error. The upper control board is not loading properly. It might flash temporarily but If it stays on the upper control board will need to be replaced.
www.twincityrepair.com
Posted on Mar 02, 2009
I have a Horizon Treadmill, Model T101 with ERROR Message 5101 MI 09. What does this mean? How do I fix it?
Hi there.... this may be a problem with the upper console CPU timing or associated parts. You can contact jatinahATrocketmailDOTcom for repair on these stalled consoles. Good Luck!
Oct 19, 2016 | Horizon Exercise & Fitness
My horizon ct5.1 turns displays select workout, buttons all beep but do not respond
replace the old batteries with a new ones, type hybrid rayovac, with the same polarity. clean the contacts batteries with c. cleaner
2) Tight the ribbon cable inside the display board.
3) Adjust the REED swithc, see the diagram attached. Test for open or faulty. Clean it, tight the connector very well.
God bless you
Jan 09, 2013 | Horizon Exercise & Fitness
Hi i have horizon treadmill t401 i don't when i start it 3 miles for hours for my workout it stoped and restart very fast i don't no what to do can u tell me how to solved the problems please
1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
Oct 07, 2012 | Horizon T401 Treadmill Walking Belt
I was using my Horizon Treadmill T1201, and in the middle of my workout my circuit breaker was tripped and lost power in my room. When I got power back, i turned on my treadmill and it reads a 5101 error...
Dear Sir:
You have a big SHORT CIRCUIT inside from your machine.
1) Test the input voltage and see the c. breaker reset 2) Test the fuse inside with your DVOM. 3) See if some wires is loose and tight 4) See if there are some component burn 5) Test the input voltage motor, if there are the motor is faulty 6) Test the output voltage for input voltage motor is there are NOT the board is FAULTY.
Of course you must sHURE the outlet from wall is o.k test the ground wires,and see any loose wires, or touching between them. DO NOT USE ANY EXTENSION CORD for your treadmill.
sincerely. God bless you
Apr 29, 2012 | Exercise & Fitness
Why is p1 flashing on my t500 treadmill
Please see your owner manual , page 18-19 you will see the Workout p1+p2+p3 etc Code for your treadmill Horizon.
If you do not have the owner manual please download:
www.horizonfitness.com, go to service customer then parts&manuals give you model, etc, and download for free.
sincerely.
Mery Christmas.
ernesto cuadra
managua, nicaragua. c.a
Dec 11, 2011 | Exercise & Fitness
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Our copier is showing error code cof32
Sir,
Your image unit my have a problems has it been replaced recently, the starter my need replacing. What model is it BizHub, Di or EP? IF it is EP model then open and close front door to reset, if Bizhub or Di model turn on and off machine wait at least ten between on and off. If these dont work then starter/developer needs replacing and or ATDC sensor needs replacing
Feb 27, 2010 | Minolta DI-2010F Copier
Exercise & Fitness Logo
734 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
