Question about Dell 924 All-in-One InkJet Printer
Paper jam in printer
Printer says their is a paper jam but its empty
  • jae44 Feb 25, 2009
    My printer, Dell 924 photo printer, is outta warranty so I disassembled it, cleaned all the rollers, ran a piece of card stock through it forwards and backwards, turned it upside down shook it, reseated the encoder strip, every solution I found on the net basically: The printer still says "Clear the paper jam. Press the > to continue." , after reassembling the same as before. 95% sure there is nothing in any one of the rollers, there is no sign of physical damage to and gear, cogs, widgets, or springs. I was wondering if there is a sensor that could have just gone bad and which one (aka locate) or it is a software issue from Dell and can I download a fix for it ???
  • 514 Answers
Go here for the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf") good luck!
Posted on Feb 28, 2009
My 8400 shows that Tray 2 is empty when it is not empty, and that the printer is suffering a paper jam when it is not suffering a paper jam.
Remove the paper, and look inside where the paper goes, if you see dust bunnies, remove them, clean the area really good, then try again.
Mar 26, 2013 | Office Equipment & Supplies
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SCX-4521F All-In-One Laser Printer states there is a document jam and toner empty but no documents are jammed and the toner has ink....cannot find the paper sensor to check if its causing the...
hello try to do this
press #1934 and right arrow key disply appear ready tech press menu &left arrow key display new cartridge press enter button twice. then toner empty message is over do previous simulation for go normal condition.
paper senser is located at back side of the machine remove backside cover and see heater unit near the hot roller paper senser is located
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
The paper feed jammed allowing some print/now says empty but not
Look at the paper path very carefully. There might be a piece of paper that got torn off and is either jammed up in the fuser or the registration assembly.
Jan 06, 2009 | Lexmark E232 Laser Printer
Printer jamming!
Check the sensor where the paper comes out of top of printer.
There is a flipper and it might be stuck or broken.
Sep 30, 2008 | HP LaserJet 4600dn Color Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Dell 924 All-in-One InkJet Printer Logo
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
