Canon CanoScan 3000F Flatbed Scanner Logo
Posted on Feb 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Couple of problems for canoscan 3000f :
Couple of problems:
(1) it scanned photos about 15 mm from its flatbed's edge.
(2) to scan A4 size, it stopped about 30 mm from the end.
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Feb 25, 2009
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247070
Points
823
It appears the scanner is not scanning in the vertical direction.(I am assuming it is able to scan the full width). Try unistall and reinstall of the friver. This can work. There are sensors in the scanner that indicate the 'end of scan area'. Check if any of them is blocked by shreds of paper or dust.
S. Mohan
If I try to scan or copy some files, it writes me: 'Error in scanner and follow instruction in manual. Scanner driver will be closed.(Code:201)'. Please help
copy and paste the link below to your browser...
http://www.google.com.ph/search?q=CanoScan+3000F+Flatbed+Scanner+code+201&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
1helpful
When I scan a letter size doc the output is only half or part of the original. Not all the page is scanned.
Here is what you should check:
1. Ensure that the original is flush against the front edge of the scanner platen (towards the scan, copy and e-mail buttons).
2. Ensure that "Paper size" is set to "Letter."
Regards,
MyEfact
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
The scanner will not process slides but performs all other copyin
The problem is resolved.
I continued searching the internet until I downloaded the Manual for ConoScan 3000F. The procedure for film scanning had a diagram of the sleeve referred to in the error report.
After removing this sleeve from the underside of the lid everything went well.
ïf all else fails read the instructions" . The problem is to find them when paper is no longer used.
Brian
2helpful
2answers
Using PaperPort 11 to scan
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
2answers
Colour change
In the Advanced tab for the scanner software, there is a tab labeled Color/Colour. On this tab, select the "Reset" button. This should return all color adjustment options to their default setting. If this does not resolve the issue, you may want to try reinstalling the software, but there is also a possibility that the unit itself has some problems.
Selecting source for 3000f
Hi, a possible explanation why the CanoScan 3000F does not show in the Source Box selection is because Windows does not recognize it as being connected. To check, you have to go to Device Manager, Imaging Devices, expand it and see if the CanoScan 3000F is installed. If it is not there, then you would have to reinstall the drivers. Another possibility is a faulty USB cable or the USB port connector itself. Try a different cable or a different USB port. Another way of looking at it is that you were able to install the scanning software but not the actual driver(s) of the scanner. Hope this be of help to you. Good luck and pls post again how things turn up.
old marine
old marine
ZJ Limited
ZJ Limited
